Seamlessly charge a USB Type-C mobile device or transfer files to a USB-C host computer, using this high quality USB-C cable. The USB-C charger cord facilitates up to 60W Power Delivery and 3A output for fast charging. It supports USB 2.0 (480Mbps) transfer rates and is suitable for general use. Designed for frequent use, the durable TPE outer jacket enhances wear protection with flexible strain reliefs and nickel-plated connectors rated beyond 10,000 insertion cycles. The 4m (13.1ft) USB-C charging cable is the ideal length for larger desk workstations where extra length is desired. Charge your USB-C devices from a USB-C wall charger, car charger, or power bank. With up to 3A of output, the USB-C charger cord supports up to 60W of Power Delivery to power a USB-C laptop, or fast charge a tablet or smartphone. Simply connect the cable from a USB-C laptop to a USB-C wall charger.
                Quality ConstructionDesigned for frequent charging, the USB-C Charger Cable features a rugged TPE outer jacket for increased wear resistance. Its flexible strain relief and nickel-plated connectors are designed to withstand over 10,000 insertion cycles, enhancing its durability and longevity.
                Charge Mobile Devices On The GoCharge a USB-C device with a USB-C wall charger, car charger, or power bank. The 4m (13.1ft) USB Type-C cable is the ideal length for larger desk workstations where extra length is desired.
                Power a LaptopWith up to 3A of output, the USB-C Charger Cord supports up to 60W of Power Delivery to charge a USB-C laptop, or fast charge a tablet or smartphone. To use, connect the cable from a USB-C laptop to a USB-C wall charger.
- StarTech.com 13ft (4m) USB-C Charging Cable, USB C Cable, 60W 3A PD - USB-C cable - 24 pin USB-C to 24 pin USB-C - 4 m
- USB-C cable
- Technology
- Shielded
- USB Power Delivery (60W), passive cable, sync and charge, 10000 insertions lifespan, polyamide housing, EMI protection, strain relief, minimum bend radius 8 mm, halogen free, 480 Mbps data rate
- Length
- 4 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Voltage
- 5 / 9 / 12 / 15 / 20 V
- Rated Current
- 3 A
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 24/30
- Rated Voltage
- Rated Current
- 3 A
- Plated Connector
- Nickel
- Length
- 4 m
- Outside Diameter
- 4.5 mm
- Black
- 143 g
- Connector
- USB / USB 2.0, RoHS, WEEE, USB Power Delivery 2.0
- Shipping Width
- 22 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 2.5 cm
- Shipping Weight
- 153 g
