StarTech.com 13ft USB-C Charging Cable
Quicklinx: J4L4WS00 Mfr#: USB2CC4MBKE
29 In Stock
£10.86 ex VAT
£13.03 inc VAT
Seamlessly charge a USB Type-C mobile device or transfer files to a USB-C host computer, using this high quality USB-C cable. The USB-C charger cord facilitates up to 60W Power Delivery and 3A output for fast charging. It supports USB 2.0 (480Mbps) transfer rates and is suitable for general use. Designed for frequent use, the durable TPE outer jacket enhances wear protection with flexible strain reliefs and nickel-plated connectors rated beyond 10,000 insertion cycles. The 4m (13.1ft) USB-C charging cable is the ideal length for larger desk workstations where extra length is desired. Charge your USB-C devices from a USB-C wall charger, car charger, or power bank. With up to 3A of output, the USB-C charger cord supports up to 60W of Power Delivery to power a USB-C laptop, or fast charge a tablet or smartphone. Simply connect the cable from a USB-C laptop to a USB-C wall charger.
  • Quality Construction
    Designed for frequent charging, the USB-C Charger Cable features a rugged TPE outer jacket for increased wear resistance. Its flexible strain relief and nickel-plated connectors are designed to withstand over 10,000 insertion cycles, enhancing its durability and longevity.
  • Charge Mobile Devices On The Go
    Charge a USB-C device with a USB-C wall charger, car charger, or power bank. The 4m (13.1ft) USB Type-C cable is the ideal length for larger desk workstations where extra length is desired.
  • Power a Laptop
    With up to 3A of output, the USB-C Charger Cord supports up to 60W of Power Delivery to charge a USB-C laptop, or fast charge a tablet or smartphone. To use, connect the cable from a USB-C laptop to a USB-C wall charger.
StarTech.com 13ft (4m) USB-C Charging Cable, USB C Cable, 60W 3A PD - USB-C cable - 24 pin USB-C to 24 pin USB-C - 4 m
USB-C cable
Shielded
USB Power Delivery (60W), passive cable, sync and charge, 10000 insertions lifespan, polyamide housing, EMI protection, strain relief, minimum bend radius 8 mm, halogen free, 480 Mbps data rate
Length
4 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
5 / 9 / 12 / 15 / 20 V
Rated Current
3 A
USB / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
24/30
Rated Voltage
Rated Current
3 A
Plated Connector
Nickel
Length
4 m
Outside Diameter
4.5 mm
143 g
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, RoHS, WEEE, USB Power Delivery 2.0
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2.5 cm
Shipping Weight
153 g
