StarTech.com 13ft DisplayPort 1.4 8K 60Hz
Quicklinx: GJJWWS00 Mfr#: DP14VMM4M
Length: 4m
£30.32 ex VAT
£36.38 inc VAT
VESA Certified DisplayPort 1.4 Cable - 8K 60Hz HDR10 - 13.1 ft. (4 m).
  • High-performance visuals
    Experience stunning visuals with support for resolutions up to 8K at 60 Hz and 4K at 120 Hz, suitable for high-detail applications.
  • Durable construction
    The cable is built with aluminum mylar foil shielding and a thermoplastic elastomer jacket, ensuring long-lasting performance in various environments.
  • Audio versatility
    Supports 32 audio channels and features HDR10 for a comprehensive audiovisual experience, enhancing sound quality.
  • Fast data transmission
    Delivers a data rate of 32.4 Gbps, suitable for applications requiring reliable data transfer.
  • Certification and compliance
    Meets RoHS standards and is VESA certified, assuring compatibility and safety for users.
StarTech 13ft (4m) VESA Certified DisplayPort 1.4 Cable, 8K 60Hz HDR10, Ultra HD 4K 120Hz DP Video Cable, DisplayPort to DisplayPort Cable, DP Cord for Monitors/Displays, M/M - DP 1.4 Cable with Latches (DP14VMM4M) - DisplayPort cable - DisplayPort to DisplayPort - 4 m
DisplayPort cable
Shielded
Molded, passive cable, 8K60Hz (7680 x 4320) support, 4K120Hz (3840 x 2160) support, strain relief, HBR3 support, Display Stream Compression 1.2 (DSC), DisplayPort Multi-Stream Transport (MST), 32 audio channels, HDR10 support, 7.1 audio channel support, Chroma subsampling (4:4:4), 32.4 Gbps data rate, Forward Error Correction, 5.1 audio channel support
Cable Length
4 m
Connector
20 pin DisplayPort - male
Connector (Second End)
DisplayPort 1.4
Grey, black
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
28
Plated Connector
Gold
Cable Length
4 m
Outside Diameter
7.5 mm
Grey, black
Connector
DisplayPort 1.4, RoHS, HDCP 2.2, 8K VESA certified
Shipping Width
33 cm
Shipping Depth
25.5 cm
Shipping Height
2 cm
Shipping Weight
328 g
Length: 4m
