StarTech.com 13ft/4m Premium Certified HDMI 2.0 Cable
Quicklinx: GXSZWS00 Mfr#: HDMMV4M
Length: 4m
29 In Stock
£17.08 ex VAT
£20.49 inc VAT
HIGH PERFORMANCE CABLE: 13ft (4m) Premium Certified High-Speed HDMI cable with Ethernet supports 4K 60Hz (3840x2160), 18Gbps bandwidth, HDR10, Ultra-wide aspect ratio, ARC, 3D video, 32 Ch audio (5.1/7.1/Dolby TrueHD/Atmos), BT.2020 colorimetry.
PREMIUM HDMI 2.0 CABLE: Ultra HD 4K 60Hz HDMI cord is engineered and built to improve signal integrity - Featuring connector bodies encased in die-cast aluminum to prevent EMI induced signal degradation; Corrosion-resistant gold-plated connectors.
DURABLE: Tested to withstand 10,000+ insertions and 600+ bend cycles at 120° angle - Durable TPE jacket with soft molded TPE strain reliefs counters the stress of frequent bends - TPE is non-toxic and halogen free.
APPLICATIONS: Ideal for home/office, works with computer/laptop/desktop/PC/workstation - UHD HDMI cord to connect TV/monitor/display/projector, Samsung/Sony/Apple TV/Dell/LG - Works w/ HDMI 2.0 Ultra HD, and other resolutions.
SPECS: 13 feet (4 meter) - HDMI 2.0 - Premium Certified HDMI Cable - High-Speed Cable with Ethernet - Color: Gray and Black - HDMI Male to Male - Outer Diameter: 0.25" (6.5 mm) - 28 AWG - Jacket: TPE - EMI Shield: Al-Mylar Foil Braid
  • Premium High-Speed Certification
    The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center to ensure it supports high-bandwidth enabled features. An EMI test is performed to ensure minimal interference from wireless signals.
  • Key Features
    • Aluminum-mylar foil with braided shielding improves EMI protection • Long-lasting flexible TPE jacket and strain reliefs • TPE is a non-toxic and halogen-free • Corrosion-resistant gold-plated connectors ensure premium video quality and enhanced reliability This premium cable has been tested to withstand 10,000+ insertions. This product is backed for life, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 13ft (4m) Premium Certified HDMI 2.0 Cable - High-Speed Ultra HD 4K 60Hz HDMI Cable with Ethernet - HDR10, ARC - UHD HDMI Video Cord - For UHD Monitors, TVs, Displays - M/M - HDMI cable with Ethernet - 4 m
Cable
Premium High Speed - HDMI cable with Ethernet
Shielded
American Wire Gauge (AWG)
28
Length
4 m
Grey, black
Connector
HDMI - male
Connector (Second End)
HDMI - male
Passive cable, 4K60Hz (3840 x 2160) support
Cable Type
Premium High Speed - HDMI cable with Ethernet passive, 4K60Hz (3840 x 2160) support
Shielded
28
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
4 m
Plated Connector
Gold
Audio Return Channel (ARC), Dolby TrueHD support, Dolby DTS-HD Master Audio support, Dolby Atmos support, support HDR10, Dolby DTS 5.1 support, Dolby DTS:X support, 3D ready, colourimetry BT.2020 support, 18 Gbps data rate, Dolby DTS 7.1 support, strain relief, outer diameter 6.5mm
Grey, black
Connector
19 pin HDMI Type A - male
RoHS, WEEE, EMI
Shipping Width
39.5 cm
Shipping Depth
13.8 cm
Shipping Height
6 cm
Shipping Weight
190 g
Limited warranty - lifetime
GXSZ StarTech.com 16ft/5m Premium Certified HDMI 2.0 Cable In Stock £17.65
Length: 4m
