This laptop privacy screen is compatible with the 13.5-inch Surface Book and Surface Laptop. The touchscreen capability, bubble-free installation, and an included storage sleeve complement this essential accessory for your compatible Surface devices.
Prevent Visual Eavesdropping
This privacy filter is a convenient and cost-effective solution to protect confidential data from unwanted viewers. The privacy shield darkens your Surface Book or Surface Laptop from the sides while providing a clear viewing angle of 60 degrees (+/- 30 degrees from center) to the user. -
Anti-Glare Filter
The privacy screen protector features an anti-glare matte finish on both sides for bright environments. The filter provides additional screen protection with a fingerprint and scratch-resistant coating. The privacy shield has a light transmittance of 57.5% providing optimal screen brightness and enhanced levels of privacy. -
Hassle-free Installation
The privacy filter is an exact fit design that will not interfere with top-mounted webcams, sensors, or when closing the lid. Affix the privacy screen shield using transparent mounting tabs. -
Blue Light Reduction
Reduce eye strain and improve visual comfort with this blue light reducing privacy shield. It blocks up to 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
- StarTech.com 13.5-inch Surface Laptop / Surface Book Privacy Screen, Anti-Glare Privacy Filter with 51% Blue Light Reduction, Monitor Screen Protector with +/- 30 deg. Viewing Angle - Matte Finish (135S-PRIVACY-SCREEN) - notebook privacy filter (horizontal)
- Product Type
- Notebook privacy filter (horizontal)
- Package Content
- Adhesive strips, sleeve, wiping cloth, quick start guide
- Transparent
- Product Material
- Plastic
- 30.5 cm 21.3 cm
- 27 g
- Display Screen Size Compatibility
- 13.5"
- Anti-glare, reversible, fingerprint-resistant coating, +/- 30° visible angle, Hassle-free installation, 51% blue light reduction
- 2-year warranty
- Designed For
- Microsoft Surface Book (13.5 in), Book 2 (13.5 in), Book 3 (13.5 in), Laptop (13.5 in), Laptop 2 (13.5 in), Laptop 3 (13.5 in), Laptop 4 (13.5 in), Laptop 5 (13.5 in)
- Product Type
- Product Material
- Plastic
- Package Content
- 30.5 cm
- 21.3 cm
- Thickness
- 0.3 mm
- 27 g
- Shipping Dimensions (WxDxH) / Weight
- 38.5 cm x 24.5 cm x 0.2 cm / 174 g
- 13.5"
- Transparent
- Finish
- Glossy, matte
Display Filter
- Aspect Ratio
- 3:2
- Scratch Resistant
- Limited warranty: - 2 years
- Designed For
StarTech.com Privacy Screen Adhesive Strips | In Stock | £5.85 |
