StarTech.com 13.5in Laptop Privacy Screen
Quicklinx: HDGJWS00 Mfr#: 135S-PRIVACY-SCREEN
Device Type: Laptop
Type: Privacy Screen
Device Screen Size: 13.5
Colour: Transparent
More than 50 In Stock
£29.58 ex VAT
£35.49 inc VAT
This laptop privacy screen is compatible with the 13.5-inch Surface Book and Surface Laptop. The touchscreen capability, bubble-free installation, and an included storage sleeve complement this essential accessory for your compatible Surface devices.
  • Prevent Visual Eavesdropping
    This privacy filter is a convenient and cost-effective solution to protect confidential data from unwanted viewers. The privacy shield darkens your Surface Book or Surface Laptop from the sides while providing a clear viewing angle of 60 degrees (+/- 30 degrees from center) to the user.
  • Anti-Glare Filter
    The privacy screen protector features an anti-glare matte finish on both sides for bright environments. The filter provides additional screen protection with a fingerprint and scratch-resistant coating. The privacy shield has a light transmittance of 57.5% providing optimal screen brightness and enhanced levels of privacy.
  • Hassle-free Installation
    The privacy filter is an exact fit design that will not interfere with top-mounted webcams, sensors, or when closing the lid. Affix the privacy screen shield using transparent mounting tabs.
  • Blue Light Reduction
    Reduce eye strain and improve visual comfort with this blue light reducing privacy shield. It blocks up to 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
StarTech.com 13.5-inch Surface Laptop / Surface Book Privacy Screen, Anti-Glare Privacy Filter with 51% Blue Light Reduction, Monitor Screen Protector with +/- 30 deg. Viewing Angle - Matte Finish (135S-PRIVACY-SCREEN) - notebook privacy filter (horizontal)
Notebook privacy filter (horizontal)
Package Content
Adhesive strips, sleeve, wiping cloth, quick start guide
Transparent
Product Material
Plastic
30.5 cm 21.3 cm
27 g
Display Screen Size Compatibility
13.5"
Anti-glare, reversible, fingerprint-resistant coating, +/- 30° visible angle, Hassle-free installation, 51% blue light reduction
Microsoft Surface Book (13.5 in), Book 2 (13.5 in), Book 3 (13.5 in), Laptop (13.5 in), Laptop 2 (13.5 in), Laptop 3 (13.5 in), Laptop 4 (13.5 in), Laptop 5 (13.5 in)
Product Material
Plastic
Package Content
30.5 cm
21.3 cm
Thickness
0.3 mm
27 g
38.5 cm x 24.5 cm x 0.2 cm / 174 g
13.5"
Transparent
Finish
Glossy, matte
Display Filter
Aspect Ratio
3:2
Scratch Resistant
Limited warranty: - 2 years
HDGJ StarTech.com Privacy Screen Adhesive Strips In Stock £6.09
Device Type: Laptop
Colour: Transparent
