StarTech.com 13.5in 3:2 Laptop Touch Privacy Screen
Quicklinx: HM9GWS00 Mfr#: 135CT-PRIVACY-SCREEN
Device Type: Laptop
Type: Privacy Screen
Device Screen Size: 13.5
Colour: Translucent black
£29.25 ex VAT
£35.10 inc VAT
This Laptop Privacy Screen is designed to work with laptops with 13.5-inch displays and 3:2 aspect ratio.
  • Prevent visual eavesdropping
    This privacy filter is a convenient and cost-effective solution to protect confidential data from unwanted viewers. The privacy shield darkens your computer's screen from the side while providing a clear viewing angle of 60 degrees (+/- 30 degrees from center) to the user.
  • Flip-Over and Touch
    The feature enables you to quickly flip-over the privacy filter to share contents without uninstalling the filter. Your computer touch responsiveness is preserved by the ultrathin yet robust security shield, enabling seamless use. The privacy shield has a light transmittance of 60% providing optimal screen brightness and enhanced levels of privacy.
  • Hassle-free Installation
    Install the privacy screen protector using the included adhesive strips or flip-over tabs. This unit is designed for use with bezel-less or slim bezel displays.
  • Blue Light Reduction
    Reduce eye strain and improve visual comfort by reducing blue light exposure. The 13.5-inch laptop screen filter blocks up to 51% of the blue light emitted from the display. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
StarTech.com 13.5-inch 3:2 Touch Privacy Screen, Anti-Glare Privacy Filter, Laptop Monitor Screen Protector with +/- 30 Deg. View Angle, Flip-Over - 51% Blue Light Reduction (135CT-PRIVACY-SCREEN) - notebook privacy filter
Notebook privacy filter
Installation Type
Adhesive, hinge tabs, flip hinges
Package Content
Adhesive strips, wiping cloth, plastic sleeve, 2 flip-over tabs, lifting tab
30.5 cm x 21.3 cm
27 g
Display Screen Size Compatibility
13.5"
+/- 30° visible angle, 51% blue light reduction
Package Content
30.5 cm
21.3 cm
Thickness
0.3 mm
27 g
38.9 cm x 24.5 cm x 0.4 cm / 215 g
13.5"
Display Filter
Installation Type
Aspect Ratio
3:2
Mounting Kit
Included
Limited warranty: - 2 years
Device Type: Laptop
