StarTech.com 13.3in MacBook Privacy Screen
Quicklinx: HSVJWS00 Mfr#: 133MF-PRIVACY-SCREEN
10 In Stock
£30.82 ex VAT
£36.98 inc VAT
The StarTech.com 13.3in MacBook Pro M1/M2 Laptop Privacy Screen is a solution for MacBook Pro users seeking to protect their sensitive information from prying eyes. With its 2-way privacy protection, this screen protector ensures that your data is visible only to you, even in public or crowded spaces. Installation is straightforward, thanks to the included adhesive strips, flip-over tabs, and lifting tab, allowing for a secure fit without compromising the sleek design of your device. It also features an anti-glare and blue light reduction filter, significantly reducing eye strain and increasing your work comfort. The screen protector is scratch-resistant, ensuring that your MacBook Pro's screen remains in pristine condition. Whether you're working in a cafe, on public transport, or in any other public place, the StarTech.com privacy screen keeps your information private and your screen protected.
  • Enhanced privacy
    The 13.3in MacBook Pro M1/M2 Laptop Privacy Screen ensures your sensitive information remains confidential with its 2-way privacy protection, offering peace of mind in public spaces.
  • Versatile installation
    Featuring adhesive, hinge tabs, and flip hinges, this privacy filter offers flexible installation options to suit your preference and maintain the sleek look of your MacBook Pro.
  • Durable and clear
    Crafted from high-quality plastic, this screen protector is scratch-resistant, ensuring your screen stays in pristine condition. The anti-glare and blue light reduction features also help in reducing eye strain during long hours of use.
StarTech.com 13.3in MacBook Pro M1/M2 Laptop Privacy Screen, Anti-Glare and Blue Light Reduction Privacy Filter, Screen Protector with +/- 30° View, Flip-Over - notebook privacy filter (horizontal)
Notebook privacy filter (horizontal) - 2-way
Installation Type
Removable - adhesive, hinge tabs, flip hinges
Package Content
Wiping cloth, 1 set of adhesive strips, 2 flip-over tabs, lifting tab
Product Material
Plastic
29.9 cm 19.5 cm
100 g
Display Screen Size Compatibility
13.3"
Anti-glare, fingerprint-resistant coating, +/- 30° visible angle, 60% light transmittance
Product Material
Plastic
Package Content
29.9 cm
19.5 cm
Thickness
0.5 mm
100 g
24.5 cm x 39 cm x 0.4 cm / 174 g
13.3"
Display Filter
Privacy Protection
2-way
Installation Type
Aspect Ratio
16:10
Scratch Resistant
Limited warranty: - 2 years
