StarTech.com 13.3in Laptop Privacy Screen
Quicklinx: HSVKWS00 Mfr#: 133T6-PRIVACY-SCREEN
£28.12 ex VAT
£33.74 inc VAT
The StarTech.com 13.3-inch 16:9 Laptop Touch Privacy Screen, Flip-Up, is a comprehensive solution designed to protect sensitive information displayed on your screen while providing eye comfort and versatile installation options. With its 2-way privacy protection, viewers from the side are blocked out, thanks to the innovative microlouver technology, ensuring your data stays private. The screen also boasts a 51% reduction in blue light, helping to reduce eye strain during prolonged use. Additionally, its anti-glare properties enhance screen readability in various lighting conditions. Installation is made easy and adaptable with the inclusion of adhesive strips, hinge tabs, and flip hinges, catering to your specific needs. The package comes complete with a wiping cloth and plastic sleeve, ensuring your privacy screen remains clean and protected. Whether you're working in a cafe, on a plane, or at a shared workspace, this privacy screen is the perfect accessory for anyone looking to secure their information and work comfortably anywhere.
  • Enhanced privacy
    Equipped with 2-way privacy protection, this 13.3-inch laptop touch privacy screen ensures your data remains confidential, making it ideal for high-traffic areas and public spaces. The microlouver technology limits the viewing angle to +/- 30°, effectively keeping your information private from prying eyes.
  • Eye comfort
    Designed with your eye health in mind, this privacy screen reduces blue light emission by 51%, minimizing eye strain during long working hours. The anti-glare feature also enhances screen visibility, providing a comfortable viewing experience in various lighting conditions.
  • Versatile installation
    This privacy screen offers multiple installation options, including adhesive strips, hinge tabs, and flip hinges, ensuring a secure fit for your laptop. The inclusion of a lifting tab facilitates easy attachment and removal, making it convenient for users who are on-the-go.
StarTech.com 13.3-inch 16:10 Laptop Touch Privacy Screen, Flip-Up - notebook privacy filter
Notebook privacy filter - 2-way
Installation Type
Adhesive, hinge tabs, flip hinges
Package Content
1 set of adhesive strips, 2 flip-over tabs, lifting tab, plastic sleeve, wiping cloth, 1 set of mounting tabs
Transparent
Product Material
Plastic
28.8 cm x 18 cm
100 g
Display Screen Size Compatibility
13.3"
51% blue light reduction, +/- 30° visible angle, Microlouver technology, horizontal orientation, anti-glare
Product Material
Plastic
Package Content
28.8 cm
18 cm
Thickness
0.5 mm
100 g
24.5 cm x 39 cm x 0.4 cm / 206 g
13.3"
Transparent
Display Filter
Privacy Protection
2-way
Installation Type
Aspect Ratio
16:10
Mounting Kit
Included
Limited warranty: - 2 years
