This laptop privacy screen features a universal design, compatible with 13.3" laptops with a 16:9 aspect ratio.
Prevent visual eavesdropping
This privacy filter is a convenient and cost-effective solution to protect your confidential data from unwanted viewers. The privacy shield darkens your laptop screen from the sides while providing a clear viewing angle of +/-30 degrees, offering a total visible area of 60 degrees. -
Reversible Filter
The privacy screen protector is reversible, with an anti-glare matte side for environments prone to glare and a high-gloss side that helps retain color vibrancy. The matte side provides additional screen protection with a fingerprint-resistant coating. -
Hassle-free Installation
The universal design won't interfere with top-mounted webcams, sensors, or when closing the lid. The privacy screen can be installed in two different ways. Affix the privacy screen shield to bezel-less displays using the transparent and residue-free adhesive strips. Alternatively, use the slide mount tabs to install the privacy screen on displays with bezels. The latter is recommended when frequent reversal or removal is required. -
Blue Light Reduction
Reduce eye strain and improve visual comfort with this blue light reducing privacy shield. It blocks 40% - 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision. This TAA-compliant laptop privacy filter is backed for two years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 13.3in Laptop Privacy Screen, Anti-Glare Privacy Filter for Widescreen (16:9) Displays, Laptop Monitor Screen Protector with 51% Blue Light Reduction - Reversible Matte/Glossy Sides (133L-PRIVACY-SCREEN) - notebook privacy filter (horizontal) - TAA Compliant
- Product Type
- Notebook privacy filter (horizontal)
- Installation Type
- Removable
- Package Content
- Wiping cloth, 1 set of adhesive strips, 1 set of slide mount tabs
- Transparent
- Product Material
- Plastic
- 29.4 cm 16.6 cm
- 90 g
- Display Screen Size Compatibility
- 13.3"
- Reversible anti-glare, reversible, 51% blue light reduction
- TAA Compliant
- 2-year warranty
- Product Type
- Product Material
- Plastic
- Package Content
- 29.4 cm
- 16.6 cm
- Thickness
- 0.5 mm
- 90 g
- Shipping Dimensions (WxDxH) / Weight
- 38.5 cm x 26 cm x 0.2 cm / 150 g
- 13.3"
- Reversible
- Transparent
Display Filter
- Installation Type
- Removable
- Aspect Ratio
- 16:9
- Anti-glare, reversible, 51% blue light reduction
- TAA Compliant
- Limited warranty: - 2 years
StarTech.com 14in Laptop Privacy Screen | In Stock | £29.56 |
StarTech.com 14in MacBook Privacy Screen | In Stock | £30.99 |
StarTech.com 16in MacBook Privacy Screen | In Stock | £31.12 |
StarTech.com 13.5in Laptop Privacy Screen | In Stock | £29.12 |
StarTech.com 15.6" Laptop Privacy Filter | In Stock | £29.07 |
StarTech.com 17.3" Laptop Privacy Filter | In Stock | £31.79 |
StarTech.com 14in MacBook Privacy Screen | In Stock | £32.46 |
StarTech.com 14in Laptop Privacy Screen | In Stock | £31.15 |
StarTech.com 15.6in Laptop Privacy Screen | In Stock | £28.33 |
StarTech.com 16in MacBook Privacy Screen | In Stock | £32.66 |
