StarTech.com 13" Surface Pro Privacy Screen
Quicklinx: HQ1HWS00 Mfr#: 13SP-PRIVACY-SCREEN
Device Type: Surface Pro
Type: Privacy Screen
Device Screen Size: 13
Colour: Black
10 In Stock
£20.45 ex VAT
£24.54 inc VAT
This Privacy Screen for 13-inch Surface Pro 8, 9, and X models smoothly transitions from a clear view to an obscured screen beyond the intended viewing angle, significantly enhancing visual privacy in office or public environments. The anti-glare matte finish helps to reduce reflections in glare-prone environments and provides additional screen protection with a scratch and fingerprint-resistant coating.
  • 4-Way Privacy and Touch Support
    The security filter ensures optimal privacy in portrait or landscape orientations when viewed beyond 30° from the center, covering a total visible area of 60°. It supports touchscreen input and gestures, preserving the interactive experience of an Surface Pro laptop while maintaining the confidentiality of on-screen content.
  • Installation
    The screen protector is compatible with the 13" Surface Pro 8, 9, and X models and features a precise fit that does not interfere with the display, camera, or speakers. The included installation kit and step-by-step instructions allow for a one-time application to the computer screen.
  • Blue Light Reduction
    This Blue Light Reduction Privacy Shield reduces eye strain and improves visual comfort by blocking 40% - 51% of the blue light emitted from the display (in the 380nm - 480nm wavelength range). Symptoms of digital eye strain, such as headaches, dry eyes, and blurred vision, can be alleviated by using blue-light filtering privacy screens.
StarTech.com 4-Way Privacy Screen For 13-inch Surface Pro 8/9/X Laptop, For Portrait/Landscape, Touch-Enabled, +/- 30 Deg. View - Computer Security Filter/Protector Blocks up to 51% Blue Light, Anti-Glare Finish (13SP-PRIVACY-SCREEN) - notebook privacy filter (horizontal)
Notebook privacy filter (horizontal) - 4-way
Installation Type
Adhesive
Package Content
Squeegee, sleeve, wiping cloth, cleaning wipes, 2 guide stickers
Product Material
Plastic
28.3 cm x 20.4 cm
100 g
Display Screen Size Compatibility
13"
Fingerprint-resistant coating, +/- 30° visible angle, 51% blue light reduction
Microsoft Surface Pro 8, Pro 9, Pro X
Product Material
Plastic
Package Content
28.3 cm
20.4 cm
Thickness
0.4 mm
100 g
39 cm x 24.5 cm x 0.4 cm / 184 g
13"
Display Filter
Privacy Protection
4-way
Installation Type
Adhesive
Scratch Resistant
Mounting Kit
Included
Limited warranty: - 2 years
Colour: Black
