The IM12D1500P Universal Power Adapter (12V DC, 1.5A) can be used as a replacement or spare AC adapter for many of StarTech.com's products, including KVM switches, media extenders and converters, drive enclosures and A/V devices.
- StarTech.com DC Adapter - 12V Adapter - 1.5A - Universal Power Adapter - AC Adapter - DC Power Supply - DC Power Cord - Replacement Adapter (IM12D1500P) - power adapter
- Power adapter - external
- 190 g
- Localisation
- North America, United Kingdom, Europe
- Input Voltage
- AC 100-240 V
- Output Voltage
- 12 V
- Black
- 5 cm x 7 cm x 4 cm
- 2-year warranty
- Designed For
- P/N: IES81GW, IREXT2, NETRS232485W, ST121HDBTDK, ST121HDBTE, ST121HDBTL, ST121HDBTPW, ST121HDBTRP, ST121HDBTSC, ST121HDBTU, ST121SHD50, ST124HDMI2, ST128HDMI2, STDHVHDBT, SV231DPDDUA, SV231DPDDUA2, SV431DPDDUA2, SV431DPUA, SV431DPUA2, SV565UTPUL, SVA12M2NEUA, SVA12M5NA, VS221HDQ, VS440HDMI
- Black
- Localisation
- Input Voltage
- AC 100-240 V
- Output Voltage
- 12 V
- Max Electric Current
- 1.5 A
- Cables Included
- Power cable - integrated - 1.4 m
- FCC, RoHS
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- 5 cm
- 7 cm
- 4 cm
- 190 g
- Designed For
- P/N: IES81GW, IREXT2, NETRS232485W, ST121HDBTDK, ST121HDBTE, ST121HDBTL, ST121HDBTPW, ST121HDBTRP, ST121HDBTSC, ST121HDBTU, ST121SHD50, ST124HDMI2, ST128HDMI2, STDHVHDBT, SV1641HDIE, SV1641HDIEGB, SV231DD2DUA, SV231DDVDUA, SV231DPDDUA, SV231DPDDUA2, SV431DD2DUA, SV431DDVDUA, SV431DPDDUA2, SV431DPUA, SV431DPUA2, SV565UTPUL, SVA12M2NEUA, SVA12M5NA, VS221HDQ, VS440HDMI
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £233.24 |
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £243.20 |
StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £114.49 |
StarTech.com 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub | In Stock | £153.35 |
StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £240.14 |
StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio | In Stock | £189.49 |
StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft | In Stock | £288.51 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £287.60 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £452.75 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.65 |
StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub | In Stock | £124.31 |
StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £142.79 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £273.74 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.95 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.71 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.02 |
StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V | In Stock | £40.15 |
