StarTech.com 12V DC 1.5A Universal Power Adapter
Quicklinx: 7NZ8WS00 Mfr#: IM12D1500P
18 In Stock
£15.73 ex VAT
£18.87 inc VAT
The IM12D1500P Universal Power Adapter (12V DC, 1.5A) can be used as a replacement or spare AC adapter for many of StarTech.com's products, including KVM switches, media extenders and converters, drive enclosures and A/V devices.
StarTech.com DC Adapter - 12V Adapter - 1.5A - Universal Power Adapter - AC Adapter - DC Power Supply - DC Power Cord - Replacement Adapter (IM12D1500P) - power adapter
Power adapter - external
190 g
North America, United Kingdom, Europe
Input Voltage
AC 100-240 V
Output Voltage
12 V
5 cm x 7 cm x 4 cm
P/N: IES81GW, IREXT2, NETRS232485W, ST121HDBTDK, ST121HDBTE, ST121HDBTL, ST121HDBTPW, ST121HDBTRP, ST121HDBTSC, ST121HDBTU, ST121SHD50, ST124HDMI2, ST128HDMI2, STDHVHDBT, SV231DPDDUA, SV231DPDDUA2, SV431DPDDUA2, SV431DPUA, SV431DPUA2, SV565UTPUL, SVA12M2NEUA, SVA12M5NA, VS221HDQ, VS440HDMI
Input Voltage
AC 100-240 V
Output Voltage
12 V
Max Electric Current
1.5 A
Power cable - integrated - 1.4 m
FCC, RoHS
0 - 80%
5 cm
7 cm
4 cm
190 g
P/N: IES81GW, IREXT2, NETRS232485W, ST121HDBTDK, ST121HDBTE, ST121HDBTL, ST121HDBTPW, ST121HDBTRP, ST121HDBTSC, ST121HDBTU, ST121SHD50, ST124HDMI2, ST128HDMI2, STDHVHDBT, SV1641HDIE, SV1641HDIEGB, SV231DD2DUA, SV231DDVDUA, SV231DPDDUA, SV231DPDDUA2, SV431DD2DUA, SV431DDVDUA, SV431DPDDUA2, SV431DPUA, SV431DPUA2, SV565UTPUL, SVA12M2NEUA, SVA12M5NA, VS221HDQ, VS440HDMI
7NZ8 StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £239.06
7NZ8 StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £249.28
7NZ8 StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £117.90
7NZ8 StarTech.com 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub In Stock £157.19
7NZ8 StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £246.14
7NZ8 StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £131.32
7NZ8 StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £197.31
7NZ8 StarTech.com DisplayPort USB KVM Switch In Stock £230.07
7NZ8 StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
7NZ8 StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.73
7NZ8 StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub In Stock £128.47
7NZ8 StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD In Stock £146.35
7NZ8 StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
7NZ8 StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
7NZ8 StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
7NZ8 StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
