StarTech.com 12U WM Bracket for 12 INCH Equipment
Quicklinx: CLVVWS00 Mfr#: WALLMNT12
Product Type: Wall mount bracket
Hurry, only 3 left in stock!
£119.16 ex VAT
£142.99 inc VAT
Mount equipment that is up to 12 inches deep, such as patch panels or network switches, to your wall. This wall-mount bracket provides 12U of space for mounting shallow rack-mount equipment that's 12 in. deep or less to the wall, such as patch panels or network switches.
The 12U rack optimizes your working space by efficiently mounting your shallow equipment on your wall instead of taking up desk space or other usable surface areas. It's the perfect solution for your space-limited SoHo (small office, home office) environment or server room because it doesn't take up any floor space.
The wall rack is constructed of solid steel to ensure a sturdy and safe mounting solution for your mission-critical equipment. Also, because the wall-mount rack's mounting holes are positioned 16 in. apart, it exactly matches standard drywall construction framework to ensure simple and secure wall-stud anchoring. The rack also features a rear access panel that can be used to easily run cabling into the rack.
Cage nuts and screws are included with the wall-mount bracket, to save you the hassle of sourcing separate mounting hardware.
If you're looking for a shallow mounting solution with fewer rack units, StarTech.com also offers a 6U wall-mount bracket, and an 8U wall-mount bracket.
  • Improve efficiency and accessibility in your workspace
    The 12U rack optimizes your working space by efficiently mounting your shallow equipment on your wall instead of taking up desk space or other usable surface areas. It's the perfect solution for your space-limited SoHo environment or server room because it doesn't take up any floor space.
  • Ensure a secure and hassle-free installation
    The wall rack is constructed of solid steel to ensure a sturdy and safe mounting solution for your mission-critical equipment. The rack also features a rear access panel that can be used to easily run cabling into the rack.
StarTech.com Wall Mount Patch Panel Rack - 15U Wall Mount Rack - 2 Post Open Frame Rack - Wall Mount Network Patch Panel (WALLMNT12) - wall mount bracket - 12U
Wall mount bracket
Package Content
M5 cage nuts, M5 screws, M6 cage nuts
Height (Rack Units)
12U
Product Material
Steel
52.1 cm x 30.5 cm x 54 cm
56.7 kg
Wall mount bracket
Product Material
Steel
Package Content
Height (Rack Units)
12U
52.1 cm
30.5 cm
54 cm
56.7 kg
Inner Dimensions
45 cm x 52.1 cm
Mounting Kit
Included
Limited warranty: - lifetime
CLVV StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
CLVV StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.91
CLVV StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £48.26
CLVV StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.39
CLVV StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.99
CLVV StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
CLVV StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
CLVV StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £55.20
CLVV StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £29.89
CLVV StarTech.com 50 Pkg M6 Cage Nuts In Stock £19.69
CLVV StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
CLVV StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
CLVV StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £52.24
CLVV StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £27.56
CLVV StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.48
CLVV StarTech.com 100 Pkg M5 Mounting Screws In Stock £30.19
CLVV StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.16
CLVV StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.84
CLVV StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.45
CLVV StarTech.com 12U WM Bracket for 12 INCH Equipment In Stock £119.16
CLVV StarTech.com 8U WM Bracket for 12in Equipment In Stock £101.09
CLVV StarTech.com 4U Wall Mount Rack, 13.78in Deep, 19 inch Wall Mount Network In Stock £44.88
CLVV StarTech.com M6 Mounting Screws 50Pack In Stock £16.74
CLVV StarTech.com 2U Wall-Mount Bracket In Stock £31.71
CLVV StarTech.com 2-Post 8U Wall Mounted Rack In Stock £68.63
