Store your servers, network and telecommunications equipment in an adjustable 12U open-frame rack. The 4POSTRACK12U 12U Server Rack lets you store your servers, network and telecommunications equipment in a sturdy, adjustable depth open-frame rack.
Designed with ease of use in mind, this 12U rack offers easy-to-read markings for both rack units (U) and depth, with a wide range of mounting depth adjustments (22 - 40in) that make it easy to adapt the rack to fit your equipment.
This durable 4-post rack supports a static loading capacity of up to 1200lbs (544kg), and offers compliance with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494) for a universal design that's compatible with most rack equipment.
For a complete server storage solution that saves you time and hassle, the rack includes optional accessories such as casters, leveling feet and cable management hooks. The base is also pre-drilled for securely fastening the rack to the floor if needed, providing you with additional stability to better suit your server environment.
Robust construction
Crafted from steel, this server rack ensures stability and durability for long-term use. -
Versatile design
Featuring adjustable depth, this rack can accommodate different types of equipment, making it adaptable to various configurations. -
Complete assembly kit
The product comes with a comprehensive kit that includes a Phillips screwdriver, nuts, screws, and grounding wires, facilitating hassle-free assembly. -
Efficient airflow
The open frame structure allows for optimal airflow, helping to keep servers and networking equipment cool during operation. -
Substantial weight capacity
With a weight limit of 544.3 kg, this rack can support a significant amount of hardware without risk of instability.
- StarTech.com 12U 19" Open Frame Server Rack, 4 Post Adjustable Depth 23-41" Mobile, Free Standing Rolling Network/Computer Equipment Data Rack, Dell PowerEdge, HP ProLiant ThinkServer - Adjustable Server Rack (4POSTRACK12U) - rack - 12U
- Product Type
- Rack
- Rack Type
- Open frame
- Package Content
- Phillips screwdriver, 16 M6 nuts, 16 M6 screws, 2 base brackets, 2 top brackets, 48 M8 bolts, 8 corner sections, 48 M8 washers, M8 (13mm) wrench, 4 casters, 4 x levelling feet, 16 M6 flange nuts, M6 (10mm) wrench, 4 x centre sections, 2 right vertical rails, 2 left vertical rails, 4 grounding wires, 16 M6 flat washers, 24 M6 cage nuts, 24 PVC cup washers, 24 M6 Philips head screws, 4 cable management hooks, 4 hook mounting screws
- Black
- Height (Rack Units)
- 12U
- Product Material
- Steel
- 60 cm x 66.18 cm x 63.75 cm
- 17 kg
- Adjustable depth, flat pack, 4 post rack mountable, 4 post
- 2-year warranty
- Designed For
- P/N: CABCAGENT62B, CABCAGENTS62, CABCAGENUT2B, CABCAGENUT6B, CABCAGENUTS2, CABCAGENUTSB, CABSCREWM52B, CABSCREWM5B, CABSCREWM62B, CABSCREWM6B, CABSCREWSB, CABSCREWSM5, CABSCREWSM5B, CABSCREWSM62, CABSCREWSM6B, CABSCRWS1224, CABSCRWSM62B
- Product Type
- Rack
- Rack Type
- Open frame
- Product Material
- Steel
- Package Content
- 12U
- 60 cm
- 66.18 cm
- 63.75 cm
- 17 kg
- Inner Dimensions
- 46.5 cm x 55.9 cm x 53.8 cm
- Black
- Weight Limit
- 544.3 kg
- Mounting Kit
- Included
- EIA-310-E, RoHS, DIN 41494, IEC 60297-3-100, ECA-310-E
- Limited warranty: - 2 years , Technical support: - lifetime
- Designed For
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £96.93 |
StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £79.46 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.66 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £32.14 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) | In Stock | £351.41 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £29.75 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £54.39 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £57.53 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £26.48 |
StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf | In Stock | £91.54 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £287.42 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £323.73 |
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £543.36 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £91.50 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £100.69 |
StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £65.78 |
StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £78.70 |
StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £80.56 |
StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters | In Stock | £363.55 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg | In Stock | £74.28 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £83.04 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £46.33 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £37.00 |
StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £55.64 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.68 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £40.38 |
StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks | In Stock | £213.48 |
StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg | In Stock | £162.59 |
StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg | In Stock | £162.18 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £49.33 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £18.74 |
StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £202.12 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £24.18 |
StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £173.48 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £61.28 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.63 |
StarTech.com 25U 36in Server Rack Cabinet | In Stock | £745.62 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £58.00 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £31.28 |
StarTech.com 19in Cable Management Panel | In Stock | £24.18 |
StarTech.com Vented 1U Rack Shelf - 10in | In Stock | £21.05 |
StarTech.com 15U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth | In Stock | £196.82 |
StarTech.com 18U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth | In Stock | £201.42 |
StarTech.com 8U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth | In Stock | £164.96 |
