StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks
Quicklinx: 9YY3WS00 Mfr#: 4POSTRACK12U
Product Type: Rack, Rack
£169.35 ex VAT
£203.22 inc VAT
Store your servers, network and telecommunications equipment in an adjustable 12U open-frame rack. The 4POSTRACK12U 12U Server Rack lets you store your servers, network and telecommunications equipment in a sturdy, adjustable depth open-frame rack.
Designed with ease of use in mind, this 12U rack offers easy-to-read markings for both rack units (U) and depth, with a wide range of mounting depth adjustments (22 - 40in) that make it easy to adapt the rack to fit your equipment.
This durable 4-post rack supports a static loading capacity of up to 1200lbs (544kg), and offers compliance with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494) for a universal design that's compatible with most rack equipment.
For a complete server storage solution that saves you time and hassle, the rack includes optional accessories such as casters, leveling feet and cable management hooks. The base is also pre-drilled for securely fastening the rack to the floor if needed, providing you with additional stability to better suit your server environment.
  • Robust construction
    Crafted from steel, this server rack ensures stability and durability for long-term use.
  • Versatile design
    Featuring adjustable depth, this rack can accommodate different types of equipment, making it adaptable to various configurations.
  • Complete assembly kit
    The product comes with a comprehensive kit that includes a Phillips screwdriver, nuts, screws, and grounding wires, facilitating hassle-free assembly.
  • Efficient airflow
    The open frame structure allows for optimal airflow, helping to keep servers and networking equipment cool during operation.
  • Substantial weight capacity
    With a weight limit of 544.3 kg, this rack can support a significant amount of hardware without risk of instability.
StarTech.com 12U 19" Open Frame Server Rack, 4 Post Adjustable Depth 23-41" Mobile, Free Standing Rolling Network/Computer Equipment Data Rack, Dell PowerEdge, HP ProLiant ThinkServer - Adjustable Server Rack (4POSTRACK12U) - rack - 12U
Rack
Rack Type
Open frame
Package Content
Phillips screwdriver, 16 M6 nuts, 16 M6 screws, 2 base brackets, 2 top brackets, 48 M8 bolts, 8 corner sections, 48 M8 washers, M8 (13mm) wrench, 4 casters, 4 x levelling feet, 16 M6 flange nuts, M6 (10mm) wrench, 4 x centre sections, 2 right vertical rails, 2 left vertical rails, 4 grounding wires, 16 M6 flat washers, 24 M6 cage nuts, 24 PVC cup washers, 24 M6 Philips head screws, 4 cable management hooks, 4 hook mounting screws
Height (Rack Units)
12U
Product Material
Steel
60 cm x 66.18 cm x 63.75 cm
17 kg
Adjustable depth, flat pack, 4 post rack mountable, 4 post
P/N: CABCAGENT62B, CABCAGENTS62, CABCAGENUT2B, CABCAGENUT6B, CABCAGENUTS2, CABCAGENUTSB, CABSCREWM52B, CABSCREWM5B, CABSCREWM62B, CABSCREWM6B, CABSCREWSB, CABSCREWSM5, CABSCREWSM5B, CABSCREWSM62, CABSCREWSM6B, CABSCRWS1224, CABSCRWSM62B
Rack
Rack Type
Open frame
Product Material
Steel
Package Content
Height (Rack Units)
12U
60 cm
66.18 cm
63.75 cm
17 kg
Inner Dimensions
46.5 cm x 55.9 cm x 53.8 cm
Weight Limit
544.3 kg
Mounting Kit
Included
EIA-310-E, RoHS, DIN 41494, IEC 60297-3-100, ECA-310-E
Limited warranty: - 2 years , Technical support: - lifetime
9YY3 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
9YY3 StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.45
9YY3 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
9YY3 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
9YY3 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
9YY3 StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
9YY3 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
9YY3 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
9YY3 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
9YY3 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
9YY3 StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.30
9YY3 StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £91.53
9YY3 StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
9YY3 StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
9YY3 StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
9YY3 StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
9YY3 StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £100.66
9YY3 StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £62.88
9YY3 StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £72.65
9YY3 StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.01
9YY3 StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters In Stock £363.55
9YY3 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
9YY3 StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £76.49
9YY3 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.75
9YY3 StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
9YY3 StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.28
9YY3 StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
9YY3 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £51.38
9YY3 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
9YY3 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.24
9YY3 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
9YY3 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
9YY3 StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks In Stock £208.39
9YY3 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £158.72
9YY3 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £162.14
9YY3 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
9YY3 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.75
9YY3 StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £197.30
9YY3 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
9YY3 StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £169.35
9YY3 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
9YY3 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
9YY3 StarTech.com 25U 36in Server Rack Cabinet In Stock £730.55
9YY3 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
9YY3 StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
9YY3 StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
9YY3 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
9YY3 StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
9YY3 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
9YY3 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
9YY3 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
9YY3 Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
9YY3 StarTech.com 19in Cable Management Panel In Stock £24.18
9YY3 StarTech.com Vented 1U Rack Shelf - 10in In Stock £21.05
9YY3 StarTech.com 15U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £192.13
9YY3 StarTech.com 18U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £196.63
9YY3 StarTech.com 8U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £157.93
9YY3 StarTech.com Heavy Duty Casters for Server Racks/Cabinets - Set of 4 In Stock £36.61
9YY3 StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
Product Type: Rack
Product Type: Rack
