StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters
Quicklinx: 80HJWS00 Mfr#: RK1236BKF
Type: Floor standing
U Height: 12U
£363.54 ex VAT
£436.24 inc VAT
Store your servers, network and telecommunications equipment securely in this 12U solid steel rack. The RK1236BKF 12U 36in Knock-Down Server Rack/Cabinet (with Casters) features a vented acrylic front door and mesh rear door, to provide devices stored in the cabinet with cost-effective passive cooling as well as offer security for your valuable equipment. Supporting a total load capacity of 800 kg (1760 lbs), the server rack is constructed of steel and aluminum to ensure a sturdy platform for valuable server/networking equipment. The included casters make this product a flexible rack solution for any IT environment or server closet, by making it easier to position the rack in the ideal location. The rack is easy to assemble at the point of installation for rapid deployment and features a flat-packed design that helps to minimize shipping costs.
  • Save money, with a cost effective, compact shipping container
    The cabinet comes in a flat packed box to reduce shipping volume, which significantly reduces your costs in shipping. Plus, because the rack is packaged efficiently, you can easily store the cabinet, for deployment at a later date.
StarTech.com 12U AV Rack Cabinet - Network Rack with Glass Door - 19 inch Computer Cabinet for Server Room or Office (RK1236BKF) - rack - 12U
Rack
Rack Type
Cabinet
Rack Size
36"
Height (Rack Units)
12U
Product Material
Aluminium, steel
29.3 kg
Wheels, lockable front door, window style door, mesh rear door
Rack
Rack Type
Cabinet
Product Material
Aluminium, steel
Rack Size
36"
Height (Rack Units)
12U
29.3 kg
Weight Limit
800 kg
RoHS, IEC 297-2, DIN 41491 Part 1
Limited warranty: - lifetime
80HJ StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
80HJ StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.84
80HJ StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.58
80HJ StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
80HJ StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
80HJ StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
80HJ StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £8.24
80HJ StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £11.53
80HJ StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
80HJ StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.59
80HJ StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
80HJ StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
80HJ StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.30
80HJ StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
80HJ StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
80HJ StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £618.82
80HJ StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
80HJ StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £100.85
80HJ StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £62.88
80HJ StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £72.65
80HJ StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.01
80HJ StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters In Stock £363.54
80HJ StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £17.22
80HJ StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £74.28
80HJ StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.75
80HJ StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
80HJ StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.28
80HJ StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
80HJ StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £51.38
80HJ StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
80HJ StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
80HJ StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
80HJ StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £158.72
80HJ StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £162.45
80HJ StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
80HJ StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.75
80HJ StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
80HJ StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £169.35
80HJ StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
80HJ StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
80HJ StarTech.com Portable Server Rack - 9U In Stock £267.95
80HJ StarTech.com 25U 36in Server Rack Cabinet In Stock £730.55
80HJ StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
80HJ StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
80HJ StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
80HJ StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
80HJ StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
80HJ StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.86
80HJ StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
80HJ StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
80HJ StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
80HJ StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
80HJ StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters In Stock £514.25
80HJ StarTech.com 19in Cable Management Panel In Stock £24.18
80HJ StarTech.com 15U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £444.20
80HJ StarTech.com 18U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £490.26
80HJ StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
U Height: 12U
