Store your servers, network and telecommunications equipment securely in this 12U solid steel rack. The RK1236BKF 12U 36in Knock-Down Server Rack/Cabinet (with Casters) features a vented acrylic front door and mesh rear door, to provide devices stored in the cabinet with cost-effective passive cooling as well as offer security for your valuable equipment. Supporting a total load capacity of 800 kg (1760 lbs), the server rack is constructed of steel and aluminum to ensure a sturdy platform for valuable server/networking equipment. The included casters make this product a flexible rack solution for any IT environment or server closet, by making it easier to position the rack in the ideal location. The rack is easy to assemble at the point of installation for rapid deployment and features a flat-packed design that helps to minimize shipping costs.
Save money, with a cost effective, compact shipping container
The cabinet comes in a flat packed box to reduce shipping volume, which significantly reduces your costs in shipping. Plus, because the rack is packaged efficiently, you can easily store the cabinet, for deployment at a later date.
- StarTech.com 12U AV Rack Cabinet - Network Rack with Glass Door - 19 inch Computer Cabinet for Server Room or Office (RK1236BKF) - rack - 12U
- Product Type
- Rack
- Rack Type
- Cabinet
- Black
- Rack Size
- 36"
- Height (Rack Units)
- 12U
- Product Material
- Aluminium, steel
- 29.3 kg
- Wheels, lockable front door, window style door, mesh rear door
- Limited lifetime warranty
- Product Type
- Rack
- Rack Type
- Cabinet
- Product Material
- Aluminium, steel
- Rack Size
- 36"
- 12U
- 29.3 kg
- Black
- Weight Limit
- 800 kg
- RoHS, IEC 297-2, DIN 41491 Part 1
- Limited warranty: - lifetime
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £94.63 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £45.84 |
StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £79.45 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £12.20 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.66 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £30.71 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) | In Stock | £351.41 |
StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £8.24 |
StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £11.53 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.44 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.24 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £54.39 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £57.53 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £25.30 |
StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf | In Stock | £91.53 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £280.59 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £317.20 |
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £543.36 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £86.88 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £100.66 |
StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £62.88 |
StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £72.65 |
StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £77.01 |
StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters | In Stock | £363.55 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £15.50 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg | In Stock | £76.49 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £81.75 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £56.70 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £44.28 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £37.00 |
StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £51.38 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.24 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £6.36 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £38.59 |
StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg | In Stock | £158.72 |
StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg | In Stock | £162.14 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £47.16 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £17.75 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £23.11 |
StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £169.35 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £56.58 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.63 |
StarTech.com Portable Server Rack - 9U | In Stock | £267.95 |
StarTech.com 25U 36in Server Rack Cabinet | In Stock | £730.55 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £20.19 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £9.55 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £5.39 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £53.55 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £28.25 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £29.69 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.56 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.01 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.11 |
StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters | In Stock | £514.25 |
Startech.com 100 Pkg M6 Mounting Screws | In Stock | £26.84 |
StarTech.com 19in Cable Management Panel | In Stock | £24.18 |
StarTech.com 15U Server Rack Cabinet - Includes Casters and Leveling Feet | In Stock | £435.23 |
StarTech.com 18U Server Rack Cabinet - Includes Casters and Leveling Feet | In Stock | £490.27 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.56 |
