StarTech.com 12U 22in Depth Hinged Open Frame Wall Mount Server Rack
Quicklinx: 8G5CWS00 Mfr#: RK1219WALLOH
U Height: 12U
Depth (mm): 55.5cm
Type: Wall Mount
Width (mm): 60.4cm
Hurry, only 3 left in stock!
£248.09 ex VAT
£297.70 inc VAT
Wall-mount your server or networking equipment with a hinged rack design for easy access and maintenance. The RK1219WALLOH 12U 22in Depth Hinged Open Frame Wall Mount Server Rack lets you wall mount your (19-inch wide) servers, A/V or network equipment and features a hinged rack design that allows the entire frame to swing open for easy installation and maintenance of your equipment.
The 12U wallmount rack offers a 4 post design for additional support of your equipment, storing a maximum weight capacity of 63 kg (140 lbs). Constructed of high-quality SPCC cold-rolled steel for strength and durability, the open frame wallmount server rack allows for maximum airflow, and ships complete with all of the rack screws and cage nuts required to mount your equipment, saving the expense of purchasing them separately.
StarTech.com 12U Hinged Open Frame Wall Mount Server Rack - 4 Post 22 in. Depth Network Equipment Rack Cabinet - 140 lbs capacity (RK1219WALLOH) - rack - 12U
Rack
Placing / Mounting
Wall mountable
Package Content
48 cage nuts, 48 mounting screws (10-32)
Rack Size
22"
Height (Rack Units)
12U
Product Material
Cold-rolled steel
60.4 cm x 55.5 cm x 64.7 cm
17.5 kg
Hinged
Rack
Placing / Mounting
Wall mountable
Product Material
Cold-rolled steel
Package Content
Rack Size
22"
Height (Rack Units)
12U
60.4 cm
55.5 cm
64.7 cm
17.5 kg
Weight Limit
63.4 kg
Hinged
EIA-310-D, UL, RoHS
Limited warranty: - lifetime
8G5C StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
8G5C StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.91
8G5C StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.39
8G5C StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.99
8G5C StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
8G5C StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
8G5C StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £129.80
8G5C StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £17.22
8G5C StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
8G5C StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.21
8G5C StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.20
8G5C StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.24
8G5C StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
8G5C StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.31
8G5C StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £22.90
8G5C StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £55.20
8G5C StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £29.89
8G5C StarTech.com 50 Pkg M6 Cage Nuts In Stock £19.69
8G5C StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
8G5C StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
8G5C StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £52.24
8G5C StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £27.56
8G5C StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.48
8G5C StarTech.com 100 Pkg M5 Mounting Screws In Stock £30.19
8G5C StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.16
8G5C StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.84
8G5C StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.45
8G5C StarTech.com 19in Cable Management Panel In Stock £23.58
8G5C StarTech.com M6 Mounting Screws 50Pack In Stock £16.74
U Height: 12U
Depth (mm): 55.5cm
Type: Wall Mount
Width (mm): 60.4cm
