Install your computer fan at the desired location inside the computer case, without stretching or straining the connection. The TX3EXT12 T X3 power extension cable lets you extend the power connection between a computer power supply and a TX3 fan by up to 1ft, allowing you to more conveniently install the fan where needed in the computer case without having to stretch or strain the connection.
- StarTech.com 12in TX3 Fan Power Extension Cable - fan power extension cable - 3 PIN internal power to 3 PIN internal power - 30.5 cm
- Fan power extension cable
- Length
- 30.5 cm
- Connector
- 3 PIN internal power - male
- Connector (Second End)
- 3 PIN internal power - female
- Limited lifetime warranty
- Length
- 30.5 cm
- Connector
- RoHS
