StarTech.com 12in Slimline SATA to SATA with LP4 Power Cable Adapter
Quicklinx: 7P2FWS00 Mfr#: SLSATAF12
Length: 30cm
Type: SATA
£7.64 ex VAT
£9.16 inc VAT
Connect a slimline SATA drive to a standard SATA motherboard connector. The SLSATAF12 Slimline SATA to SATA with LP4 Power Cable (12-inch) features a SATA data receptacle and a Molex (LP4) power connection on one end, and a Slimline Serial ATA receptacle on the other - allowing you to connect a slim SATA drive to a computer motherboard that does not have a Slimline connection available.
Supporting full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives, this innovative adapter cable provides you with the connections needed to simplify the migration to Slimline SATA-equipped drives.
StarTech.com 12in Slimline SATA to SATA with LP4 Power Cable Adapter (SLSATAF12) - SATA cable - 30 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Length
30 cm
Connectors
13 pin Slimline Serial ATA - female
Connectors (Second End)
7 pin Serial ATA - female , 4 pin internal power (12V) - male
Red
Storage Cable Type
SATA cable
Interface Speed
American Wire Gauge (AWG)
26
Length
30 cm
Red
Connectors
RoHS
7P2F StarTech.com 20in Slimline SATA to SATA with LP4 Power Cable Adapter In Stock £11.00
7P2F StarTech.com 36in Slimline SATA to SATA with LP4 Power Cable Adapter In Stock £8.44
7P2F StarTech.com 12in Slimline SATA to SATA with LP4 Power Cable Adapter In Stock £7.64
Length: 30cm
Type: SATA
