StarTech.com 12in SATA to Molex LP4 Power Cable Adapter - F/M
Quicklinx: 949XWS00 Mfr#: LP4SATAFM12
Type: Power
Hurry, only 3 left in stock!
£4.00 ex VAT
£4.80 inc VAT
Power an LP4 Molex device from a SATA Power connection on your computer power supply. The LP4SATAFM12 SATA to LP4 Power Cable Adapter enables you to power 4-pin Molex devices (i.e. hard drive, DVD-ROM drive, add-in card, etc.) from a SATA power connector on your computer power supply. Offering 12 inches in cable length, the cable allows you to position your devices as needed within the system case.
StarTech.com 12in SATA to LP4 Power Cable Adapter F/M - SATA to LP4 Power Adapter - SATA Female to LP4 Male Power Cable - 12 inch (LP4SATAFM12) - power adapter - 4 PIN internal power to SATA power - 30.48 cm
Power adapter
Length
30.48 cm
Connector
4 PIN internal power - female
Connector (Second End)
15 pin Serial ATA power - male
P/N: SATSASBP425
Power adapter
American Wire Gauge (AWG)
18
Length
30.48 cm
Connector
RoHS
P/N: SATSASBP425
949X StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £4.60
949X StarTech.com SATA to LP4 Power Cable Adapter In Stock £5.23
949X StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £6.62
949X StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M In Stock £5.78
949X StarTech.com 6" SATA Power Y Splitter Cable In Stock £6.62
Type: Power
