StarTech.com 12in SATA to Molex LP4 Power Cable Adapter - F/M
Quicklinx: 949XWS00 Mfr#: LP4SATAFM12
Type: Power
29 In Stock
£4.00 ex VAT
£4.80 inc VAT
Power an LP4 Molex device from a SATA Power connection on your computer power supply. The LP4SATAFM12 SATA to LP4 Power Cable Adapter enables you to power 4-pin Molex devices (i.e. hard drive, DVD-ROM drive, add-in card, etc.) from a SATA power connector on your computer power supply. Offering 12 inches in cable length, the cable allows you to position your devices as needed within the system case.
  • Flexible connectivity
    Equipped with a 15 pin Serial ATA power male connector and a 4 pin internal power female connector, this adapter allows versatile connections for various SATA drives.
  • Compact length
    At 12 inches long, this cable provides enough length to connect components without excess clutter, maintaining a clean setup.
  • Durable design
    Built with 18 AWG copper wire, this power adapter is designed for reliability and effective power transmission.
  • Eco-friendly compliance
    This product is RoHS compliant, ensuring it meets environmental safety standards.
StarTech.com 12in SATA to LP4 Power Cable Adapter F/M - SATA to LP4 Power Adapter - SATA Female to LP4 Male Power Cable - 12 inch (LP4SATAFM12) - power adapter - 4 PIN internal power to SATA power - 30.48 cm
Power adapter
Length
30.48 cm
Connector
4 PIN internal power - female
Connector (Second End)
15 pin Serial ATA power - male
P/N: SATSASBP425
Power adapter
American Wire Gauge (AWG)
18
Length
30.48 cm
Connector
RoHS
P/N: SATSASBP425
949X StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.02
949X StarTech.com SATA to LP4 Power Cable Adapter In Stock £3.80
949X StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £7.04
949X StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M In Stock £5.78
949X StarTech.com 6" SATA Power Y Splitter Cable In Stock £7.04
Type: Power
