Power an LP4 Molex device from a SATA Power connection on your computer power supply. The LP4SATAFM12 SATA to LP4 Power Cable Adapter enables you to power 4-pin Molex devices (i.e. hard drive, DVD-ROM drive, add-in card, etc.) from a SATA power connector on your computer power supply. Offering 12 inches in cable length, the cable allows you to position your devices as needed within the system case.
- StarTech.com 12in SATA to LP4 Power Cable Adapter F/M - SATA to LP4 Power Adapter - SATA Female to LP4 Male Power Cable - 12 inch (LP4SATAFM12) - power adapter - 4 PIN internal power to SATA power - 30.48 cm
- Power adapter
- Length
- 30.48 cm
- Connector
- 4 PIN internal power - female
- Connector (Second End)
- 15 pin Serial ATA power - male
- Limited lifetime warranty
- Designed For
- P/N: SATSASBP425
- Power adapter
- American Wire Gauge (AWG)
- 18
- Length
- 30.48 cm
- Connector
- RoHS
- Designed For
- P/N: SATSASBP425
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.48 |
StarTech.com SATA to LP4 Power Cable Adapter | In Stock | £5.24 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £7.40 |
StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M | In Stock | £5.71 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £7.40 |
