Power an LP4 Molex device from a SATA Power connection on your computer power supply. The LP4SATAFM12 SATA to LP4 Power Cable Adapter enables you to power 4-pin Molex devices (i.e. hard drive, DVD-ROM drive, add-in card, etc.) from a SATA power connector on your computer power supply. Offering 12 inches in cable length, the cable allows you to position your devices as needed within the system case.
Flexible connectivity
Equipped with a 15 pin Serial ATA power male connector and a 4 pin internal power female connector, this adapter allows versatile connections for various SATA drives. -
Compact length
At 12 inches long, this cable provides enough length to connect components without excess clutter, maintaining a clean setup. -
Durable design
Built with 18 AWG copper wire, this power adapter is designed for reliability and effective power transmission. -
Eco-friendly compliance
This product is RoHS compliant, ensuring it meets environmental safety standards.
 - StarTech.com 12in SATA to LP4 Power Cable Adapter F/M - SATA to LP4 Power Adapter - SATA Female to LP4 Male Power Cable - 12 inch (LP4SATAFM12) - power adapter - 4 PIN internal power to SATA power - 30.48 cm
 - Power adapter
- Length
 - 30.48 cm
- Connector
 - 4 PIN internal power - female
- Connector (Second End)
 - 15 pin Serial ATA power - male
 - Limited lifetime warranty
- Designed For
 - P/N: SATSASBP425
 - Power adapter
- American Wire Gauge (AWG)
 - 18
- Length
 - 30.48 cm
- Connector
 - RoHS
- Designed For
 - P/N: SATSASBP425
                        StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.42 |
                        StarTech.com SATA to LP4 Power Cable Adapter | In Stock | £3.80 |
                        StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £7.04 |
                        StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M | In Stock | £5.79 |
                        StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £7.04 |
