Extend your LP4 power connections by up to 12 inches. The LP4POWEXT12 Extension Cable features two 4-pin Molex power connectors, one male and one female, and offers 12-inches in cable length, enabling you to extend your LP4 power connections and allowing you to position your devices (i.e. hard drive, DVD-ROM drive, add-in card, etc.) as needed within the system case.
- StarTech.com 12in Molex LP4 Power Extension Cable M/F - 4 pin Molex Power Connector - 4 pin Power Extension Cable - LP4 Power Cable (LP4POWEXT12) - power extension cable - 4 PIN internal power to 4 PIN internal power - 30.48 cm
- Power extension cable
- Length
- 30.48 cm
- Connector
- 4 PIN internal power - male
- Connector (Second End)
- 4 PIN internal power - female
- Limited lifetime warranty
- Designed For
- P/N: PYO2L, SATAPOWADAP
- American Wire Gauge (AWG)
- 18
- Length
- 30.48 cm
- Connector
- Designed For
StarTech.com 12in Molex LP4 Power Extension Cable – M/F
