StarTech.com 12in Molex LP4 Power Extension Cable – M/F
Quicklinx: 9649WS00 Mfr#: LP4POWEXT12
Length: 30.48cm
32 In Stock
£4.44 ex VAT
£5.32 inc VAT
Extend your LP4 power connections by up to 12 inches. The LP4POWEXT12 Extension Cable features two 4-pin Molex power connectors, one male and one female, and offers 12-inches in cable length, enabling you to extend your LP4 power connections and allowing you to position your devices (i.e. hard drive, DVD-ROM drive, add-in card, etc.) as needed within the system case.
StarTech.com 12in Molex LP4 Power Extension Cable M/F - 4 pin Molex Power Connector - 4 pin Power Extension Cable - LP4 Power Cable (LP4POWEXT12) - power extension cable - 4 PIN internal power to 4 PIN internal power - 30.48 cm
Power extension cable
Length
30.48 cm
Connector
4 PIN internal power - male
Connector (Second End)
4 PIN internal power - female
P/N: PYO2L, SATAPOWADAP
American Wire Gauge (AWG)
18
Length
30.48 cm
Connector
Length: 30.48cm
