This 12in LP4 to SATA Power Y Cable Adapter features two Serial ATA power (female) connectors and one LP4 male connection - a reliable solution that lets you power two SATA drives using a single LP4 connection to the computer power supply. This durable LP4/SATA Y cable adapter is 1ft in length, giving you enough cable slack to position drives as needed within the computer case while saving the cost and hassle of upgrading a power supply for compatibility with Serial ATA drives.
- StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter - Molex to to Dual SATA Power Adapter Splitter - power adapter - 4 PIN internal power to SATA power
- Power adapter
- Connector
- 4 PIN internal power - male
- Connector (Second End)
- 2 x 15 pin Serial ATA power - female
- Limited lifetime warranty
- Designed For
- P/N: 25S22M2NGFFR, 25SAT22MSAT, ATXPOW330HS, ATXPOW350PRO, ATXPOW400DF, ATXPOWER300B, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, S25SLOTR, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257
- Power adapter
- Connector
- Designed For
- P/N: 25S22M2NGFFR, 25SAT22MSAT, ATXPOW250PRO, ATXPOW300PRO, ATXPOW330HS, ATXPOW350DF, ATXPOW350PRO, ATXPOW400DF, ATXPOWER250, ATXPOWER300, ATXPOWER300B, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, S25SLOTR, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.48 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.20 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £7.40 |
StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA | In Stock | £4.14 |
StarTech.com 6in 4 Pin Molex to Left Angle SATA Power Cable Adapter | In Stock | £3.97 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £7.40 |
Customer reviews
Write a review for the StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter here!
Does exactly what it's meant to...
Reviewed by Gary. Review Posted 13/01/2009
What more can I say?
Length of cabling is good if there is a chance of a bit of a stretch to fit to drive...
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
