StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA
Quicklinx: 8G48WS00 Mfr#: PYO2LP4LSATA
Length: 30cm
Type: SATA
Hurry, only 3 left in stock!
£5.50 ex VAT
£6.60 inc VAT
Power two SATA drives from a single LP4 power supply connector. The PYO2LP4LSATA LP4 Molex to Dual Latching SATA power splitter cable features two Serial ATA female power connectors and one LP4 male connector - a reliable solution that enables you to power two SATA drives using a single LP4 connection to the computer power supply.
This durable LP4 to SATA Y cable adapter is 12 inches in length, giving you enough cable slack to position drives as needed within the computer case, while saving the cost and hassle of upgrading a power supply for compatibility with Serial ATA drives.
StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin LP4 to Dual SATA Y Splitter - power adapter - 4 PIN internal power to SATA power - 30 cm
Power adapter
Latched
Length
30 cm
Connector
4 PIN internal power - male
Connector (Second End)
2 x 15 pin Serial ATA power - female
P/N: 35S24M2NGFF, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, S32M2NGFFPEX, SAT32MSATPEX
Power adapter
American Wire Gauge (AWG)
20
Latched
Length
30 cm
Connector
RoHS
8G48 StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
8G48 StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.48
8G48 StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £6.34
8G48 StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA In Stock £5.50
8G48 StarTech.com 6" SATA Power Y Splitter Cable In Stock £6.34
Length: 30cm
Type: SATA
