StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable
Quicklinx: 6PFHWS00 Mfr#: LSATA12RA1
Length: 30cm
Type: SATA
£4.96 ex VAT
£5.95 inc VAT
This 12in right-angled latching SATA cable features a (straight) female Serial ATA connector as well as a right-angled (female) SATA connector, providing a simple connection to a Serial ATA drive even if space near the drive's SATA port is limited. The cable offers latching connectors, which ensure secure connections for SATA hard drives and motherboards that support this feature. Once the right-angled SATA connector has been inserted into the drive's SATA data port, the shaft of the cable is seated flush with the rear panel of the drive, eliminating the clutter of excess cable at the connection point - an ideal solution for small or micro form factor computer cases. The right angled SATA cable features a thin, narrow construction that helps to improve airflow within the computer case; the cable features a rugged, yet flexible design that makes it easy to make the SATA connection as needed.
StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable (LSATA12RA1) - SATA cable - 30 cm
SATA cable
Interface Speed
Serial ATA 150/300
Latched, right-angled connector
Length
30 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
Red
P/N: 35S24M2NGFF, CFAST2SAT25, PEXSAT32, ST521PMINT, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
Serial ATA 150/300
Length
30 cm
Red
Connector
6PFH StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
Length: 30cm
Type: SATA
