StarTech.com 12in Latching SATA Cable
Quicklinx: 4LSNWS00 Mfr#: LSATA12
Length: 30cm
Type: ATA
More than 50 in stock
£3.34 ex VAT
£4.00 inc VAT
Latching SATA connectors, for securely fastened hard drive installations. The LSATA12 SATA Cable features two latching 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 12in Latching SATA Cable - SATA cable - Serial ATA 150/300/600 - SATA (R) to SATA (R) - 1 ft - latched - red - LSATA12 - SATA cable - 30 cm
SATA cable
Interface Speed
Latched
Length
30 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: 25S22M2NGFFR, 35S24M2NGFF, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, CFAST2SAT25, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB225S3R, HSB43SATSASB, HSB4SATSASBA, PEXM2SAT32N1, PEXMSATA3422, PEXMSATA343, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SATSASBP425
Storage Cable Type
SATA cable
Interface Speed
Latched
Length
30 cm
Red
Connector
RoHS
P/N: 25S22M2NGFFR, 25SAT22MSAT, 35S24M2NGFF, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F, CFAST2SAT25, DRW110SATBK, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB225S3R, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, MSAT2SAT3, PEXM2SAT32N1, PEXMSATA3422, PEXMSATA343, PEXSAT32, PEXSAT34RH, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT2MSAT25, SAT32M225, SAT32MSAT257, SAT32MSATM, SAT32MSATPEX, SATSASBP425, USB2SATAIDE, USB3SSATAIDE
Length: 30cm
Type: ATA
Stock Status: In stock
