The StarTech.com 6" 3-pin to Large Internal Power CPU Fan Adapter Cable allows a fan with a TX3 motherboard connector to draw power from a standard LP4 power supply connector.
 - StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable (CPUFANADAPT) - power splitter - 15.2 cm
 - Power splitter
- Length
 - 15.2 cm
- Connectors
 - 4 PIN internal power - male
- Connectors (Second End)
 - 4 PIN internal power - female , 3 PIN internal power - male
 - Limited lifetime warranty
- Designed For
 - P/N: FAN370PRO, FAN7X10TX3, FANBOX2, FANDURONTB, FANP1003LD, FANP2SECC
 - Power splitter
- Length
 - 15.2 cm
- Connectors
- Designed For
