StarTech.com 12in 4 Pin Fan Power Splitter Cable - F/M
Quicklinx: 7NY0WS00 Mfr#: FAN4SPLIT12
Length: 31cm
Type: Power
46 In Stock
£5.74 ex VAT
£6.88 inc VAT
Connect two 4-pin (PWM) Fans to a Single Motherboard Fan Power Connector. The FAN4SPLIT12 Fan Power Splitter Cable enables you to connect two 4-pin (PWM) fans to a single motherboard power connector, which allows you to optimize your computer cooling capability.
Providing a flexible way to position computer case fans as needed, this 4-pin Fan Power Splitter cable offers a connection length of 1ft, eliminating the need to strain the connection between the computer power connector and the fans.
This high quality splitter cable is constructed of high quality materials to ensure long-lasting performance.
StarTech.com 12in 4 Pin Fan Power Splitter Cable - F/M - 1ft Fan Y Cable - 1ft 4-pin Fan Splitter Cable (FAN4SPLIT12) - fan power splitter - 4 pin PWM to 4 pin PWM - 31 cm
Fan power splitter
Length
31 cm
Connector
4 pin PWM - female
Connector (Second End)
2 x 4 pin PWM - male
P/N: FAN1156PWM, FAN12025PWM, FAN8025PWM
Fan power splitter
American Wire Gauge (AWG)
26
Length
31 cm
Connector
4 pin PWM - female
RoHS
7NY0 StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable In Stock £2.96
7NY0 StarTech.com 12in TX3 Fan Power Splitter Cable In Stock £3.64
7NY0 StarTech.com 6in TX3 Fan Power Splitter Cable In Stock £2.94
Length: 31cm
Type: Power
