The FAN4EXT12 12-inch 4-Pin Fan Power Extension Cable lets you extend the power connection between a computer power supply and a 4-pin fan by up to 1ft, enabling you to conveniently install the fan where needed in the computer case, without having to stretch or strain the connection.
- StarTech.com 12in 4 Pin Fan Power Extension Cable - M/F - Fan power extension cable - 4 pin PWM (M) to 4 pin PWM (F) - FAN4EXT12 - fan power extension cable - 4 pin PWM to 4 pin PWM - 30.5 cm
- Length
- 30.5 cm
- Connector
- 4 pin PWM - male
- Connector (Second End)
- 4 pin PWM - female
- Limited lifetime warranty
- American Wire Gauge (AWG)
- 28
- Length
- 30.5 cm
- Connector
- 4 pin PWM - male
