StarTech.com 12in 22 Pin SATA Power and Data Extension Cable
Quicklinx: 7TGYWS00 Mfr#: SATA22PEXT
Length: 30.5cm
Type: SATA
£6.94 ex VAT
£8.32 inc VAT
This 12-inch, 22-pin SATA22PEXT SATA Power and Data Extension Cable enables you to extend the reach between internal SATA power and data connections and a SATA hard drive by up to 1ft.
The extension simplifies drive installation by overcoming typical connection limitations, and it reduces the risk of damage to the drive or motherboard SATA connectors by eliminating the need to strain or stretch the cable in order to make the necessary data connection.
StarTech.com 12in 22 Pin SATA Power and Data Extension Cable - 1ft SATA data power Extension - 12 inch SATA Extension - SATA extension cable - 30.5 cm
Length
30.5 cm
Connector
22 pin Serial ATA - female
Connector (Second End)
22 pin Serial ATA - male
Red
Storage Cable Type
Length
30.5 cm
Red
Connector
RoHS
7TGY StarTech.com 12in 22 Pin SATA Power and Data Extension Cable In Stock £6.94
7TGY StarTech.com 12in 15 pin SATA Power Extension Cable In Stock £8.14
Length: 30.5cm
Type: SATA
