This 12-inch, 22-pin SATA22PEXT SATA Power and Data Extension Cable enables you to extend the reach between internal SATA power and data connections and a SATA hard drive by up to 1ft.
The extension simplifies drive installation by overcoming typical connection limitations, and it reduces the risk of damage to the drive or motherboard SATA connectors by eliminating the need to strain or stretch the cable in order to make the necessary data connection.
- StarTech.com 12in 22 Pin SATA Power and Data Extension Cable - 1ft SATA data power Extension - 12 inch SATA Extension - SATA extension cable - 30.5 cm
- Length
- 30.5 cm
- Connector
- 22 pin Serial ATA - female
- Connector (Second End)
- 22 pin Serial ATA - male
- Red
- Limited lifetime warranty
- Storage Cable Type
- Length
- 30.5 cm
- Red
- Connector
- RoHS
StarTech.com 20in Slimline SATA Extension Cable | In Stock | £9.13 |
StarTech.com 12in 22 Pin SATA Power and Data Extension Cable | In Stock | £6.03 |
