StarTech.com 12in 15 pin SATA Power Extension Cable
Quicklinx: 89CWWS00 Mfr#: SATAPOWEXT12
Length: 30.5cm
11 In Stock
£8.90 ex VAT
£10.68 inc VAT
Extend a SATA Power Connection by up to 12in. The SATAPOWEXT12 SATA Power Extension Cable (15-pin, 12-inch) enables you to extend the reach between internal SATA power and drive connections by up to 12 inches.
The extension cable helps to simplify drive installation by overcoming typical connection limitations and reduces the risk of damage to the drive or motherboard SATA connectors by eliminating the need to strain or stretch the cable in order to make the necessary connection.
StarTech.com 12in 15 pin SATA Power Extension Cable - SATA Power Male to Female Extender - 12 Inch SATA Power Extension Cord - power extension cable - SATA power to SATA power - 30.5 cm
Power extension cable
Length
30.5 cm
Connector
15 pin Serial ATA power - male
Connector (Second End)
15 pin Serial ATA power - female
1-year warranty
P/N: PYO2SATA, PYO4SATA, SATAPOWADAP
Length
30.5 cm
Connector
1-year warranty
89CW StarTech.com 8in 15 pin SATA Power Extension Cable In Stock £5.56
89CW StarTech.com 0.3m SATA Extension Cable In Stock £7.42
89CW StarTech.com 12in 15 pin SATA Power Extension Cable In Stock £8.90
Length: 30.5cm
