StarTech.com 120x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector
Quicklinx: 76S0WS00 Mfr#: FANBOX12
Type: Case Fan
£8.10 ex VAT
£9.72 inc VAT
The StarTech.com 12cm x 12cm x 2.5cm (4 3/4" x 4 3/4" x 1") PC case fan is an add-in cooling fan designed to fit most computers. It can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components. A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 48 CFM (cubic feet per minute) of air. Power is supplied to the fan using a standard LP4 (hard drive power connector) pass through plug.
StarTech.com 120x25mm Dual Ball Bearing Computer Case Fan w/ LP4 Connector (FANBOX12) - system fan kit
System fan kit
Fan Diameter
120 mm
Noise Level
34 dBA
12 cm x 2.5 cm x 12 cm
129 g
System fan kit
12 cm
2.5 cm
12 cm
129 g
184 g
Heatsink & Fan
Fan Diameter
120 mm
Noise Level
34 dBA
Limited warranty: - 2 years - carry-in
Type: Case Fan
