Enhance your Surface Laptop Go's screen with the StarTech.com 4-Way 12.4in Privacy Screen Filter. Designed specifically for the Surface Laptop Go 1/2/3, this filter provides a perfect fit for 12.4" displays, offering privacy and protection. With its adhesive installation, the filter stays in place without leaving any residue. It's crafted to reduce up to 51% of harmful blue light, thereby minimizing eye strain during extended use. The matte finish and anti-glare properties ensure a clear view under various lighting conditions, while the touch-enabled design allows for uninterrupted use of your device's touchscreen features. Whether you're working in public spaces or simply want to protect your screen from scratches and fingerprints, this privacy screen filter is an essential accessory for your Surface Laptop Go.
Versatile viewing
Designed for flexibility, this privacy screen filter offers both portrait and landscape modes, enabling users to switch orientations with ease while maintaining privacy and screen clarity. -
Enhanced protection
With its scratch-resistant and fingerprint-resistant coating, this filter not only protects your screen from daily wear and tear but also maintains a clean, smudge-free surface for clear viewing. -
Blue light reduction
Equipped with a feature that cuts down 51% of blue light emission, this privacy screen filter helps in reducing eye strain and increasing viewing comfort during prolonged use. -
Touch compatibility
This filter seamlessly integrates with your Surface Laptop Go's touchscreen functionality, ensuring that touch responsiveness remains unaffected while offering privacy.
- StarTech.com 4-Way 12.4in Surface Laptop Go 1/2/3 Privacy Screen Filter, Portrait/Landscape, Touch-Enabled, +/- 30 Deg. View, Blue Light Reduction, Matte Finish - notebook privacy filter (horizontal)
- Product Type
- Notebook privacy filter (horizontal)
- Installation Type
- Adhesive
- Package Content
- Squeegee, wiping cloth, cleaning wipes, dust removal sticker
- Black
- Product Material
- Plastic
- 27.5 cm x 19.5 cm
- 100 g
- Display Screen Size Compatibility
- 12.4"
- Anti-glare, fingerprint-resistant coating, portrait / landscape mode, touch screen compatible, 60° viewing, 60% light transmittance, 51% blue light reduction
- 2-year warranty
- Product Type
- Product Material
- Plastic
- Package Content
- 27.5 cm
- 19.5 cm
- Thickness
- 0.04 cm
- 100 g
- Shipping Dimensions (WxDxH) / Weight
- 24.5 cm x 38.5 cm x 0.87 cm / 200 g
- 12.4"
- Black
Display Filter
- Installation Type
- Adhesive
- Aspect Ratio
- 3:2
- Scratch Resistant
- Mounting Kit
- Included
- Limited warranty: - 2 years
