StarTech.com 11x18in Anti Static Mat
£25.55 ex VAT
£30.66 inc VAT
The desktop anti-static mat helps you protect your valuable equipment from the dangers of static electricity which can permanently damage components and render them unusable. This mat covers an area of 12 x 18 in (30 x 46 cm), ideal for manufacturing or repair facilities where electronic parts are in use. It can also be utilized in data centers, or in other any locations that requires ESD protection.
  • Excellent Construction Quality
    The anti-static mat complies with the ANSI / ESD S 4.1 surface resistance standard. The mat is composed of two PVC layers with a total thickness of 0.08 in (2 mm). The bottom black layer is textured for surface adhesion. The mat includes a coiled grounding cable which is long enough (6.6 ft / 2 m) to reach the most common grounding points.
  • Easy to Deploy and Store
    The mat is made with a flexible PVC material that allows it to be easily rolled into a tube and used as a portable work surface or for minimalist storage. A convenient snap-on clip enables the grounding wire to be attached or removed with ease. You can easily clean the mat's with an anti-static mat cleaner to keep the ESD performance and protect the work surface. The SM-ANTI-STATIC-MAT is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 11x18in Anti Static Mat, ESD Mat for Electronics Repair, Anti Static Desk Mat w/Detachable Grounding Wire, ANSI/ESD S 4.1 Compliant, Flexible Thermoplastic Work Mat/Pad - Suitable for Tables (SM-ANTI-STATIC-MAT) - anti-static mat - detachable grounding wire
Anti-static mat - detachable grounding wire
Beige
Product Material
PVC
46 cm x 30 cm x 0.2 cm
163 g
Grounding wire with alligator clip (2m)
Product Material
PVC
46 cm
30 cm
0.2 cm
163 g
31 cm x 9 cm x 9 cm / 238 g
Beige
ANSI/ESD S4.1
Limited warranty: - 2 years
20 °C
45 °C
GVL2 StarTech.com ESD Anti Static Wrist Strap In Stock £7.27
Device Type: All
Type: Upgrade part
Product Range: StarTech.com
Product Model: 11x18in Anti Static Mat, ESD Mat for Electronics Repair, Anti Static Desk Mat w/Detachable Grounding Wire, ANSI/ESD S 4.1 Compliant, Flexible Thermoplastic Work Mat/Pad - Suitable for Tables (SM-ANTI-STATIC-MAT)
