StarTech.com 10U Wall-Mount Bracket
Quicklinx: H7V7WS00 Mfr#: RACK-10U-14-BRACKET
£103.00 ex VAT
£123.60 inc VAT
The 10U 14in deep wall mounting bracket for patch panels delivers a sturdy and dependable equipment storage option, allowing you to wall mount data/IT equipment for a more efficient and accessible operating environment. It's the perfect solution for areas where space is at a premium like SoHo (small office, home office) environment, or space limited server room because it doesn't take any floor space.
  • Sturdy Construction & Easy Installation
    The mounting bracket features an all-steel design and is suitable for mounting patch panels, or other slim 19in equipment to a wall, and to organize cabling or equipment in your network closet, wiring closet, back office, or IDF. The sturdy steel construction is especially helpful for durability and stability. Also, because The open frame wall rack's mounting holes are positioned 16in. apart, allowing you a simple and secure wall-stud anchoring to your existing construction framework.
  • Includes Hardware
    M6 square cage nuts and M6 screws are included with the wall-mount bracket, additionally, M5x25 mounting screws are included to save you the hassle of sourcing separate mounting hardware. The RACK-10U-14-BRACKET is backed by a StarTech.com lifetime warranty and free lifetime technical support.
StarTech.com 10U Wall Mount Rack, 19" Wall Mount Network Rack, 14 inch Deep (Low Profile), Wall Mounting Patch Panel Bracket for Network Switches, IT Equipment, 77lb (35kg) Capacity - Network Equipment Rack (RACK-10U-14-BRACKET) - network device mounting bracket - 10U - 19"
Network device mounting bracket
Placing / Mounting
Wall mountable
Package Content
40 x M6 cage nuts, 40 x M6 cage screws, 40 x plastic washers, 4 x M5 x 25 mm mounting screws, 4 x plastic wall anchors
49.8 cm x 35.6 cm x 45.1 cm
5 kg
Product Material
Steel
Height (Rack Units)
10U
Placing / Mounting
Wall mountable
Package Content
Product Material
Steel
Height (Rack Units)
10U
49.8 cm
35.6 cm
45.1 cm
5 kg
Enclosure Colour
Rack Size
19"
Mounting Kit
Included
Weight Limit
35 kg
Integrated cable management, 2-post, 35 cm maximum mounting depth
Shipping Width
43 cm
Shipping Depth
57 cm
Shipping Height
52 cm
Shipping Weight
9.8 kg
Limited warranty - limited lifetime warranty
H7V7 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
H7V7 StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £49.48
H7V7 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
H7V7 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
H7V7 StarTech.com 2U Wall-Mount Bracket In Stock £32.50
