StarTech.com 10U 19in Side Mount Open Rack
Quicklinx: 85FGWS00 Mfr#: RK1019SIDEM
Wall-mount your server or networking equipment sideways, for easy access. The RK1019SIDEM Side-mounted Wallmount Open Frame Rack/Cabinet is a 10U rack that enables you to mount 19in (wide) servers, A/V or network equipment facing perpendicular to a wall, for easy access to mounted devices and equipment. The cabinet/rack open access to both the front and back of your devices, making it easy to adjust cabling, view LEDs and access configuration buttons as needed.
Plus, the nature of the sidemount configuration allows for deeper mounting depths than typical wallmount racks.
Constructed of high-quality SPCC cold-rolled steel, for strength and durability, the open frame rack allows for maximum airflow while still supporting a maximum weight capacity of 159 kg (350 lbs). The wall mount rack also ships complete with all of the M5 screws and cage nuts required to mount your equipment, saving the expense of purchasing them separately.
StarTech.com 10U 19in Wall Mount Side Mount Open Frame Rack Cabinet - rack - 10U
Rack
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
10U
Product Material
Steel
53.7 cm x 56 cm x 56.8 cm
19.4 kg
Rack
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
19"
Height (Rack Units)
10U
53.7 cm
56 cm
56.8 cm
19.4 kg
Weight Limit
159 kg
Mounting Kit
Included
EIA-310-D, UL, RoHS
Limited warranty: - lifetime
