StarTech.com 10m Yellow Cat6 Patch Cable
Quicklinx: CC40WS00 Mfr#: N6PATC10MYL
Length: 10m
Colour: Yellow
15 In Stock
£11.67 ex VAT
£14.00 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. This 10-meter Cat6 cable meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections. Plus, the cable features a durable yellow PVC jacket that enables you to color code your network cable runs as needed.
For easier cable runs, the snagless connectors protect the cable's RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port.
The cable features molded boots that offer connector strain relief, by stopping the RJ45 connector termination points from bending at sharp angles, and reducing the risk of damage to the cable, which could decrease network performance.
Startech 10m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Yellow, Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC10MYL) - patch cable - yellow
Patch cable - CAT 6
Molded, snagless, strain relief, minimised Near-End Crosstalk (NEXT), kink protection
Cable Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Cable Length
10 m
Yellow
Connector
RJ-45 - male
RJ-45 - male
CC40 StarTech.com 10m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable - 10 m Patch Cord In Stock £11.67
CC40 StarTech.com 10m Gray Cat6 Patch Cable In Stock £13.71
CC40 StarTech.com 10m White Cat6 Patch Cable In Stock £12.29
CC40 StarTech.com 10m Red Cat6 Patch Cable In Stock £11.67
CC40 StarTech.com 10m Orange Cat6 Patch Cable In Stock £11.67
CC40 StarTech.com 10m Green Cat6 Patch Cable In Stock £11.67
CC40 StarTech.com 10m Yellow Cat6 Patch Cable In Stock £11.67
CC40 StarTech.com 10m Purple Cat6 Patch Cable In Stock £11.67
Length: 10m
Colour: Yellow
