StarTech.com 10m Snagless Cat6 Patch Cable - Blue
Quicklinx: 84NFWS00 Mfr#: N6PATC10MBL
Length: 10m
Colour: Blue
£12.13 ex VAT
£14.55 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC10MBL Cat 6 Patch Cable (10m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a cheaper cable based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, StarTech.com cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
This Cat 6 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 10m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Blue, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC10MBL) - patch cable - 10 m - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Molded, snagless
Length
10 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
84NF StarTech.com 10m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable - 10 m Patch Cord In Stock £12.13
84NF StarTech.com 10m Snagless Cat6 Patch Cable - Blue In Stock £11.85
84NF StarTech.com 10m Gray Cat6 Patch Cable In Stock £13.76
84NF StarTech.com 10m White Cat6 Patch Cable In Stock £12.35
84NF StarTech.com 10m Red Cat6 Patch Cable In Stock £12.40
84NF StarTech.com 10m Orange Cat6 Patch Cable In Stock £11.85
84NF StarTech.com 10m Green Cat6 Patch Cable In Stock £12.40
84NF StarTech.com 10m Yellow Cat6 Patch Cable In Stock £11.85
84NF StarTech.com 10m Purple Cat6 Patch Cable In Stock £12.40
Length: 10m
Colour: Blue
