This LC to LC Multimode Duplex Fiber Optic Patch cable offers reliable connections for 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in your 40 and 100 Gigabit networks.
With laser-optimized multimode fiber (LOMMF), the patch cable is ideal for 850 nm and 1350 nm Vertical Cavity Surface Emitting Laser (VCSEL) and LED sources. The high-speed connectivity on the aqua fiber-optic cable provides a high-bandwidth solution for your data centers or high-density applications.
This fiber-optic patch cord is backward compatible with your existing 50/125 equipment, ensuring a reliable connection with legacy LANs.
Housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, this fiber-optic cable ensures minimal smoke, toxicity and corrosion when exposed to high sources of heat, or in the event of a fire. It's the best choice for a wide range of environments, including industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each OM4 fiber cable is also individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Built for Performance
With laser-optimized multimode fiber (LOMMF), the patch cable is ideal for 850 nm and 1350 nm Vertical Cavity Surface Emitting Laser (VCSEL) and LED sources. The high-speed connectivity on the aqua fiber-optic cable provides a high-bandwidth solution for your data centers or high-density applications. -
Maximum Compatibility
This fiber-optic patch cord is backward compatible with your existing 50/125 equipment, ensuring a reliable connection with legacy LANs. -
High Quality Construction
Housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, this fiber-optic cable ensures minimal smoke, toxicity and corrosion when exposed to high sources of heat, or in the event of a fire. It's the best choice for a wide range of environments, including industrial settings, central offices and schools, as well as residential settings where building codes are a consideration. Each OM4 fiber cable is also individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability. 450FBLCLC10 is backed by a StarTech.com lifetime warranty and free lifetime technical support.
- StarTech.com 10 m OM4 LC to LC Multimode Duplex Fiber Optic Patch Cable- Aqua - 50/125 - Fiber Optic Cable - 40/100Gb - LSZH (450FBLCLC10) - patch cable - 10 m - aqua
- Patch cable - OM4
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Laser-optimized multimode fibre (LOMMF)
- Length
- 10 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Aqua
- Limited lifetime warranty
- Network Cable Type
- Patch cable - OM4
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- 50 / 125 micron
- Length
- 10 m
- Aqua
- Connector
- RoHS, WEEE
- -20 °C
- 60 °C
StarTech.com 1m Aqua OM4 LC Fiber Cable | In Stock | £18.27 |
StarTech.com 2m Aqua OM4 LC Fiber Cable | In Stock | £19.60 |
StarTech.com 3m Aqua OM4 LC Fiber Cable | In Stock | £21.69 |
StarTech.com 10m OM4 LC Multimode Duplex Fiber Optic Patch Cable Aqua | In Stock | £38.42 |
StarTech.com 7m OM4 LC Multimode Duplex Fiber Optic Patch Cable - Aqua | In Stock | £31.09 |
StarTech.com 15m OM4 LC-LC Multimode Duplex Fiber Optic Patch Cable Aqua | In Stock | £52.87 |
