StarTech.com 10m LC/LC OM5 Fiber Cable
Quicklinx: HHX2WS00 Mfr#: LCLCL-10M-OM5-FIBER
Length: 10m
Colour: Green
Hurry, only 3 left in stock!
£45.93 ex VAT
£55.11 inc VAT
OM5 FIBER CABLE: The OM5 LOMMF cable is optimized for 40/100 Gbps fiber optic networks. Extended 850-953 nm wavelength support enables SWDM (Short Wavelength Division Multiplexing) for greater channel isolation.
QUALITY CONSTRUCTION: LC/LC-UPC ends for better return loss than PC polishing - Color-coded connectors for polarity - Fiber core insensitive to bending, Aramid sheathing for a maggione bend radius.
RELIABLE: individually tested for guaranteed performance (testing included). LSZH sheathing emits low toxic fumes in case of combustion. Safe in poorly ventilated spaces. Attenuation value <2.4 dB/km meets/exceeds standards.
WIDE COMPATIBILITY: OM5 multimode cable supports 10/40/100G networks, compatible with OM4/OM3. High resistance to microbending facilitates bending in complex installations, ideal for fiber switches/servers, SANs and SFP+/QSFP+/QSFP28 modules.
SPECIFICATIONS: OM5 - LC/LC (UPC) - 50/125µm - 850-953nm VCSEL/1300nm LED - Modal bandwidth: 4700MHz.km (850nm), 2470MHz.km (953nm) - Insertion loss: =0.3dB - Return loss: =30dB - Cable Ø: 2.9mm - Bend radius: 3-6cm
  • High-speed connectivity
    Experience fast data transfer rates of up to 100 Gbps, ideal for high-bandwidth applications and efficient data center operations.
  • Enhanced durability
    Constructed with a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the amount of toxic and corrosive gas emitted during combustion, ensuring a safer environment for all.
  • Optimized for laser
    Featuring Laser-optimized multimode fibers (LOMMF) with a wavelength range of 840/953/1300 nm, this cable is engineered for superior performance in VCSEL laser light sources.
  • Bend insensitive
    Designed to withstand tight bends and challenging installations, this cable maintains signal integrity and performance, reducing the risk of downtime due to cable damage.
StarTech.com 10m (30ft) LC to LC (UPC) OM5 Multimode Fiber Optic Cable, 50/125µm Duplex LOMMF Zipcord, VCSEL, 40G/100G, Bend Insensitive, Low Insertion Loss, LSZH Fiber Patch Cord - patch cable - 10 m - green
Patch cable - OM5
Duplex fibre optic
Type of Fibre Optics
Multimode
Halogen-free, up to 100 Gbps data transfer rate, Laser-optimized multimode fibre (LOMMF), wavelength of 840/953/1300 nm
Length
10 m
Diameter
2.9 mm
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC/UPC multi-mode - male
Connector (Second End)
Green
Network Cable Type
Patch cable - OM5
Duplex fibre optic
Multimode
Jacket Material
50 / 125 micron
Length
10 m
Diameter
2.9 mm
Green
Connector
RoHS, TIA/EIA-568
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
85 g
-20 °C
60 °C
HHX2 StarTech.com 10m LC/LC OM5 Fiber Cable In Stock £45.93
HHX2 StarTech.com 15m LC/LC OM5 Fiber Cable In Stock £57.55
HHX2 StarTech.com 1m LC/LC OM5 Fiber Cable In Stock £17.35
HHX2 StarTech.com 2m LC/LC OM5 Fiber Cable In Stock £19.09
HHX2 StarTech.com 5m LC/LC OM5 Fiber Cable In Stock £29.58
HHX2 StarTech.com 7m LC/LC OM5 Fiber Cable In Stock £35.49
Length: 10m
Colour: Green
