StarTech.com 10m HDMI to DVI-D Cable - M/M
Quicklinx: 7RWPWS00 Mfr#: HDDVIMM10M
Length: 10m
£14.94 ex VAT
£17.92 inc VAT
Connect an HDMI output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display.
The HDDVIMM10M 10-meter HDMI -DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-capable output to a DVI-D capable display.
A valuable addition to any home theater, digital signage or multimedia application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
StarTech.com 10m HDMI to DVI-D Cable - M/M - 10m DVI-D to HDMI - HDMI to DVI Converters - HDMI to DVI Adapter (HDDVIMM10M) - adapter cable - HDMI / DVI - 10 m
Cable
Adapter cable - HDMI / DVI
Shielded
American Wire Gauge (AWG)
24
Length
10 m
Connector
HDMI - male
Connector (Second End)
DVI-D - male
Thumbscrews
Cable Type
Adapter cable
Interface Supported
HDMI / DVI
Shielded
24
Jacket Material
PVC
Shielding Material
Length
10 m
Plated Connector
Gold
Thumbscrews
Connector
19 pin HDMI Type A - male
18+1 pin digital DVI (Single-Link) - male
Limited warranty - lifetime
7RWP StarTech.com 2m High Speed HDMI® Cable to DVI Digital Video Monitor In Stock £7.92
7RWP StarTech.com 3m HDMI to DVI-D Cable - M/M In Stock £9.63
7RWP StarTech.com 5m HDMI to DVI-D Cable – M/M In Stock £9.75
7RWP StarTech.com 1m HDMI to DVI-D Cable - M/M In Stock £7.31
7RWP StarTech.com 0.5m HDMI to DVI-D Cable - M/M In Stock £7.46
Length: 10m
