StarTech.com 10m Gray Cat6 Patch Cable
Quicklinx: B2W7WS00 Mfr#: N6PATC10MGR
Length: 10m
Colour: Grey
Hurry, only 3 left in stock!
£13.69 ex VAT
£16.42 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC10MGR Cat 6 patch cable (10m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable gray PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 10m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Grey, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC10MGR) - patch cable - 10 m - grey
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wires per Cable
4 wires
Snagless
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
4 wires
Pairs per Cable
8 pairs
Plated Connector
Gold
Snagless
Length
10 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
B2W7 StarTech.com 10m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable - 10 m Patch Cord In Stock £10.87
B2W7 StarTech.com 10m Snagless Cat6 Patch Cable - Blue In Stock £10.87
B2W7 StarTech.com 10m Gray Cat6 Patch Cable In Stock £13.69
B2W7 StarTech.com 10m White Cat6 Patch Cable In Stock £12.29
B2W7 StarTech.com 10m Red Cat6 Patch Cable In Stock £10.87
B2W7 StarTech.com 10m Orange Cat6 Patch Cable In Stock £10.87
B2W7 StarTech.com 10m Green Cat6 Patch Cable In Stock £10.87
B2W7 StarTech.com 10m Yellow Cat6 Patch Cable In Stock £10.87
B2W7 StarTech.com 10m Purple Cat6 Patch Cable In Stock £10.87
Length: 10m
Colour: Grey
Stock Status: While stocks last
Stock Status: Clearance
