StarTech.com 10m Gray Cat5e Patch Cable
Quicklinx: CWC6WS00 Mfr#: 45PAT10MGR
Length: 10m
Colour: Grey
More than 50 in stock
£5.82 ex VAT
£6.98 inc VAT
Make Fast Ethernet connections with support for PoE. This Cat5e patch cable delivers reliable network connections, which ensures high-performance capability for your demanding Ethernet applications.
This 10-meter gray network cable is perfect for use in network conduits and raceways. The cable is intended for longer distance applications, such as running up a post or throughout the office from a hub to a wall- jack.
For easier network installations, the Cat 5e cables are available in a wide variety of lengths and colors. This ensures you have the right size of cable available when you need it and it lets you color code your connections for a more organized setup.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The cable also features molded boots which offer connector strain relief by stopping the RJ45 connector termination points from bending at sharp angles. This reduces the risk of damage to the cable, which could decrease network connectivity and performance.
Get the highest value for your cable investment with the Cat5e Ethernet cables, each one manufactured using high-quality copper conductors. They are carefully constructed and tested, to keep Near-End Crosstalk (NEXT) well within acceptable limits.
Ensure high-performance capability for your demanding Ethernet applications, such as Power-over-Ethernet and 4K or 1080p video streaming, using cables that include 24 AWG copper.
You can rely on the RJ45 connectors to deliver optimum conductivity, while eliminating signal loss due to oxidation or corrosion.
StarTech.com 10m Gray Cat5e / Cat 5 Snagless Ethernet Patch Cable 10 m - patch cable - 10 m - grey
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Snagless, stranded
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Snagless, stranded
Length
10 m
325 g
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE - up to 350 MHz
CWC6 StarTech.com 10m Orange Cat5e Patch Cable In Stock £5.82
CWC6 StarTech.com 10m Black Cat5e Patch Cable In Stock £5.82
CWC6 StarTech.com 10m Blue Cat5e Patch Cable In Stock £5.82
CWC6 StarTech.com 10m Red Cat5e Patch Cable In Stock £5.82
CWC6 StarTech.com 10m Gray Cat5e Patch Cable In Stock £5.82
CWC6 StarTech.com 10m Yellow Cat5e Patch Cable In Stock £5.82
CWC6 StarTech.com 10m White Cat5e Patch Cable In Stock £5.82
CWC6 StarTech.com 10m Purple Cat5e Patch Cable In Stock £5.82
Length: 10m
Colour: Grey
Stock Status: In stock
