Connect your VGA monitor with the highest quality connection available. This 10m high resolution VGA monitor cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
- StarTech.com 10m Coax High Resolution Monitor VGA Cable HD15 M/M - VGA cable - 10 m
- VGA cable
- Technology
- Triple shielded twisted pair coaxial
- Molded
- Length
- 10 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- RoHS
- Black
- Limited lifetime warranty
- VGA cable
- Technology
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Molded
- Length
- 10 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- RoHS
StarTech.com Slimline Adapter HDDB15 F/F | In Stock | £5.05 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F | In Stock | £7.08 |
StarTech.com 10m Coax High Resolution Monitor VGA Cable - HD15 M/M | In Stock | £29.43 |
StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M | In Stock | £47.38 |
StarTech.com 20m Coax High Resolution Monitor VGA Cable - HD15 M/M | In Stock | £64.71 |
StarTech.com 2m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £8.34 |
StarTech.com 3m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £10.60 |
